DFI PS35-BL Motherboards
  • EagleTG
    • Jun 2011
    • 20
    I have repaired three of these PS35-BL motherboards that were used in GlobalVR's Need for Speed arcade games.
    One was having trouble turning on. Would pulse the fans, that was it. Replaced all of the caps and it's happy.
    One was working, but everything ran REALLY slowly when it was stressed (3D graphics, full screen video). Recapping it fixed what ailed it.
    The last, and most bizarre... Astoundingly worked PERFECTLY. However, upon inspection, I found a badly burned ATX connector and header...
    The pins that are burnt are the 3.3v supply. As logic would indicate, the caps were badly swollen on the motherboard. However, I found that there were some very bad caps on the video card as well. Video card was a PNY GeForce 4 Ti4200-8X.
    Replaced these two caps (this picture shows a temporary used replacement fan, and this was before I hit it with some compressed air, my apologies.) Prior to replacement, these particular caps were severely failing ESR test, and were obviously swollen. From what I've read, it seems that these video card caps and the bad caps on the motherboard were contributing to higher load/resistance on the 3.3v lines causing the heat issue at the ATX header.
    Here's the re-capped motherboard.
    I also replaced the power supply and the ATX header on the motherboard on this last one.
    And the games live to play again. Two up and running, and one that I stole all of the parts out of as spares.
  • Steve Moerke
    • Apr 2017
    Re: DFI PS35-BL Motherboards
    Hello EagleTG
    I have a Global VR Madden Season One stand up arcade game that won't even boot. Mine is the DFI Intel Pentium 4 DFI-PS35-BL-MAD. All the fans are running wide open and the VGA monitor says no signal. It came this way.
    I put a new power supply in it and then it had a siren that went off from low to high over and over and it still wouldn't boot. I took out the battery for more than 15 seconds, waited, put it back in and turned it on. Now the siren is gone but it still wont boot. I have tried hitting delete as well as F1 on start up and it does nothing.
    I forgot to mention that I also re-seated everything.
    I'm pretty sure I have a dead motherboard or a hard drive issue. Does anyone repair these computers, or have any idea what is wrong with it and how I can fix it myself?
    Any help would be appreciated. Would you try to repair my motherboard? Could I pay you to do it?
    Thanks,
    Steve
    • cpt.charlie
      • Sep 2013
      • 270
      • Spain
      Upload a photo of your board, maybe it's something obvious.
      • Steve Moerke
        • Apr 2017
        I really looking for someone that can re-cap the motherboard for me. Who out there can I ship this to to go through it?
        Steve
        • Steve Moerke
          • Apr 2017
          I am aware that the siren is a CPU overheat or fan failure. What does that mean? AS I said before when I turn the machine on the fan and all fans are going wide open. The fan is working on the CPU. What do I do next?
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            Steve
            https://www.badcaps.net/index.php?pageid=repair_details
            • cpt.charlie
              • Sep 2013
              • 270
              • Spain
              Connect a different 3 pin fan, maybe the tachometer of your fan isn't working properly.
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16958
                Steve
                I received your repair request. I'll get back to you tomorrow, I've been out of the office.
                <--- Badcaps.net Founder
                Badcaps.net Services:
                Motherboard Repair Services
                http://folding.stanford.edu/
                Team : 49813
                Join in!!
                Team Stats
                • bobec
                  • Jul 2017
                  Hi Steve I have just joined this forum after seeing your recent post, i have purchased a NFS Carbon full size gaming machine that was faulty,It has a ps35-bl m/board, I was informed that the video card was faulty upon investigation i found the motherboard would not boot. I tested the ram/passed,video card/ passed, power supply faulty swollen caps fan in pws not spinning, changed pws power to m/board but still no boot.
                  I removed the cpu and placed a 478 test card to the socket and it indicates a faulty m/board, i hope this info may be helpful to you, new motherboards are available on alibaba $185 AUD last time i checked cheers Rob.
                  • stefanpng
                    HP EliteDesk 800 G1 SFF solder an extra fan header?
                    by stefanpng
                    So the HP EliteDesk 800 G1 SFF has only one fan header on the whole motherboard, a 4 pin cpu. There is a second chassis fan header, but it is not installed, there are just 4 bare through holes and some silkscreen.
                    Other models like the tower version of this computer have the chassis fan header installed, so I was wondering if it was possible to solder in a new 4 pin header.
                    There is some surrounding circuitry, and I think it is identical to this schematic. The CPU fan header circuitry matches exactly except for one filter(?) cap, and the chassis...
                    07-13-2022, 05:54 PM
                  • madscientist750
                    Replacing electrolytic caps by solid caps on old motherboards
                    by madscientist750
                    I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
                    I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
                    I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
                    10-19-2025, 06:10 AM
                  • Powderfanupnorf
                    Dell AL440LX power on switch circuit help required
                    by Powderfanupnorf
                    Hi Everyone. First official post so fingers crossed I conform and also manage to get photos to work.
                    So I am requesting some help from anyone who happens to have one of these motherboards to hand and perhaps a multimeter.
                    My board has a single row of header pins for all the front panel stuff (have seen others where they are grouped together differently so thats no help) and the two pins for the power on switch had been previously repaired and I am trying to make a better repair. There looks to be pad and trace damage and im happy to relocate the header pin/pins to...
                    06-24-2024, 01:24 PM
                  • tintin_sn2
                    RTX 2070 Fan not operating - 12v present at header but drops to 2V when fan connected
                    by tintin_sn2
                    I recently purchased a second hand RTX 2070 - an OEM Acer Predator manufactured by Sapphire - not a very common model.
                    Upon connecting it up I noticed the fan wasn't operating resulting in the card overheating and shutting down. I checked the fan operation independently by connecting it directly to a power supply and function generator - it was working correctly with variable speed according to the square wave frequency.
                    I then checked the output with a multimeter/DSO and verified that the GPU was putting out both 12V at pin 2 and PWM at pin 4. However, when the fan is...
                    03-29-2024, 08:09 PM
                  • qwerty99
                    Xbox 1.6 Motherboards and Polymer Capacitors
                    by qwerty99
                    Hello!
                    I need to change the capacitors on my three original Xboxes.
                    Two of them are 1.6B revisions and have Hynix RAM, and the other one is a 1.6 with Samsung RAM.
                    The 1.6 has the infamous Nichicon HM capacitors around the CPU, which have all bulged and started to leak. This Xbox no longer powers on.
                    The 1.6B revisions have Rubycon MBZ capacitors that all look fine, but I’ll change them in due course. Both of these work fine.
                    I’ve seen some excellent threads on the forum about replacing/upgrading capacitors, but I can’t...
                    06-26-2022, 12:53 AM
