i have a video card (EVGA eGeforce 8400GS, 256MB DDR2 P/N:256-P2-N732-LR) that has a bad capacitor (FZ76 1500 6.3V [looks silver with blue writing, sealed, has the letter K perforated on the top]) i need to know where to buy a replacement, and what the resistance etc... of them are so i get the right one.
EVGA eGeforce 8400GS, 256MB DDR2 P/N:256-P2-N732-LR bad capacitor FZ76 1500 6.3V
Re: EVGA eGeforce 8400GS, 256MB DDR2 P/N:256-P2-N732-LR bad capacitor FZ76 1500 6.3V
OH NO!!!! Sacon FZ alert!
you need to do a full recap on it. any caps starting with FZ need to go.
for replacement, you have 2 options: direct replacement or poly mod.
direct replacement is using low esr electrolytic caps with the same values. simplest... and since you are using an EVGA card, you need not worry about lead spacing since the ground side is likely double holed to accept both common spacings. this is the easiest and cheapest method.
poly mods are the use of polymer capacitors to replace the 'lytics. poly mods require a bit of investigation as poly caps tend to come in a different range of voltages. the simple test is to run the card under no load (bios) and to use a multimeter to measure the voltage across the cap. since you are using 6.3v on the old, my guess would be that 4v polys would work. you also need to divide the capacitance (uf) by 2 more or less since the ESR of polys is much lower. the advantage to polys is that they are virtually immune form failure (if you use good ones).
either option should fix it... the owner of the forum actually bought a lot of dead evga 7600GT cards with blown FZ's... he did a couple in lytics and poly modded the rest... I have one of the poly cards myself, the recap will spawn new life into it.
where do you live (country)? if in the US/canada, the badcaps.net store has the caps you will need whether you poly mod or not. if you live elsewhere, post your location...sigpic
(Insert witty quote here)
by coinwizxThe power supply is 2020 Corsair HX1200 modular power supply.
Cause of damage: I connected EVGA molex cable to the Sata port and test it with a ATX tester. Since the pin out on the EVGA is wrong, result in the 12V pin shorted to the 5V pin, in the 12V back-feeded to the 5v port.
Damage: Power supply shorted out, shut off itself internally, damaged the 5v or 3v rail or the monitoring circuitry. The self protection circuit shut off the power supply when power up because it detected some abnormal/defect. I waited a few minutes, let it self reset then try to re power up.... -
by coinwizxThe power supply is 2024 newest version of NZXT C850 modular power supply.
Damage: Power supply shorted out, shut off itself internally, damaged the 5v or 3v rail or the monitoring circuitry. The self protection circuit shut off the power supply when power up because it detected some abnormal/defect. I waited a few minutes, let it self reset then... -
by onix331Asking here as a last ditch effort:
GPU: EVGA RTX2070 Black Edition XC Gaming
A few weeks ago i noticed a burning electronics smell in my room, after a bit of confusion i realized that the RGB LED light of my GPU was out. Weird.
I didn't think much of it until i tried to look at the power usage in HWinfo, i then noticed that the entry "GPU Power (Total)" was gone entirely, it would also not boost above 1410Mhz.
Looking further i noticed that "Performance Limit - Utilization" was always at "Yes". The card did perform mostly...05-27-2024, 08:34 AM -
by s_henyaHi guys,
Got this EVGA GTX750TI 2GB GPU
MB Bios is beeping when GPU is connected.
When booting with onboard GPU, MB is booting but the GTX isn't showing in windows device manager.
I would like to reprogram the bios EVGA 750Ti 2GB non-6pin 82.07.55.00.50
I searched around but couldn't fins 256kb BIOS like mine.
Anyone can please assist?...-
by Rayvenhello everyone , im looking for a schematic file for a gpu card EVGA 760 SC , i already made measurements in many places and all looking good but i want to verificate the mos critics zones and verify routes , im going to atach an a PCB photo and if anyone have the file .fz , .brd or any technical reference please sended to me , i really apreciate any help .1 Photo
10-18-2025, 09:15 PM -
- Loading...
