hp pavilion a1203w usb problems
  • mrjeep88
    • Nov 2010
    • 10
    Hi I have a problem with the usb on my hp pavilion a1203w. The computer has a asus k8s-la motherboard. The usb stopped working so I pulled off the cover and saw a bad capacitor it was a 820uf 6.3v so I replaced it with a 1000uf 10v. So now I have two rear usb and no front. My question is do I need to replace the capacitor with the exact same as the old one or do I have more problems with this board
  • bigbeark
    • Jan 2010
    • 661
    Re: hp pavilion a1203w usb problems
    Check to see that you reattached the cables to the front USB ports properly!
    Note that it's common for the motherboard to have a jumper disabling the front USB ports when they are not connected! Also check your BIOS to see if there is a Disable/Enable setting for the Front USB ports
    • mrjeep88
      • Nov 2010
      • 10
      they were working before the bad capacitor. I checked the cables twice allready but I was looking at the board the other night and noticed there is two capacitors sitting raised up on the board but tops are still flat could these also be bad ?
      • retiredcaps
        • Apr 2010
        • 9271
        Originally posted by mrjeep88
        tI was looking at the board the other night and noticed there is two capacitors sitting raised up on the board but tops are still flat could these also be bad ?
        Caps can bloat on the bottom too. See "Bushytails" photo at
        https://www.badcaps.net/forum/showthread.php?t=424
        --- begin sig file ---
        --- end sig file ---
        • mrjeep88
          • Nov 2010
          • 10
          thanks I will change out those two and see if that helps. Should I replace them with the 820uf 6.3v or can I replace them with the same 1000uf 10v. I am also thinking of just replaceing all the capacitors. I am not shure of what brand to use or even what the original ones are all they say is kzg. The board is Asus k8s-la
          • retiredcaps
            • Apr 2010
            • 9271
            KZG is United Chemicon. Sadly, the KZG series is prone to failure according to
            https://www.badcaps.net/forum/showthread.php?t=2280
            You can go higher in voltage, but you should stay with the same uF. For a test, you can use 1000uF in place of 820uF.
            For a replacement, anything that matches KZG in terms of ripple, ESR or better from the good cap list above will do fine.
            • jetadm123
              • 2169
              I agree with retiredcaps that you should replace the cap(s) with a similar value. The 1000uf you used is around 20% difference, which could be the cause of your frt USB not working. The other two caps you mentioned "could" possibly be in parallel, which would give you 2000uf total compared to 1640uf, thus, making your problems even worse. If you're in the USA, you can order caps from digikey.com and select USPS First Class Shipping for the the lowest rate. If you order a higher voltage, make sure the diameter and height fit your board.
              • mrjeep88
                • Nov 2010
                • 10
                Thanks guys I will check out digikey and see what I can come up with. The reason I ask about 1000uf is because I have quite a few of them left from doing about 20 soyo book pc's but I will replace all the bad capacitors on hp with same as what is on it
                • MORETTIGIAN
                  Capacitor detached from PCB – RTX 2070 Super Founders Edition
                  by MORETTIGIAN
                  Title:
                  Description:
                  During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                  I did not notice it detaching, so I am unsure of its original location on the PCB.
                  Procedure performed:
                  - Removed backplate
                  - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                  - Reapplied thermal compound
                  - Reassembled card
                  Observed behavior after reassembly:
                  - GPU powers on and operates normally under...
                  09-18-2025, 12:14 PM
                  HP Pavilion Pavilion Desktop - 570-a079w Pavilion 570 J4205 Specification for Upgrade or Repair
                  This specification for the HP Pavilion Pavilion Desktop - 570-a079w can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-a079w boardview and Pavilion Pavilion Desktop - 570-a079w schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                  09-12-2024, 03:44 PM
                  HP Pavilion Pavilion Wave Desktop - 600-a059na Pavilion i5-6400T Specification for Upgrade or Repair
                  This specification for the HP Pavilion Pavilion Wave Desktop - 600-a059na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Wave Desktop - 600-a059na boardview and Pavilion Pavilion Wave Desktop - 600-a059na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                  HP Pavilion Pavilion Desktop - 570-p056 Pavilion 570 i7-7700 Specification for Upgrade or Repair
                  This specification for the HP Pavilion Pavilion Desktop - 570-p056 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-p056 boardview and Pavilion Pavilion Desktop - 570-p056 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                  HP Pavilion Pavilion Desktop - 570-p030na Pavilion 570 i3-7100 Specification for Upgrade or Repair
                  This specification for the HP Pavilion Pavilion Desktop - 570-p030na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-p030na boardview and Pavilion Pavilion Desktop - 570-p030na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
