hp allione 22-b312nt led 7 times blinks
  • trmrtts
    • Jan 2014
    • 38
    • turkey
    hi
    i have hp allione 22-b312nt. when i want to start but nothing.after remove rtc batery starting .when i want to shutdown and press start buton nothing led blinking 7 time.whats my problem
  • Nairolf
    Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
    by Nairolf
    I have a Samsung DM32D display.
    When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
    Here’s what I have tried so far:
    1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
    2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
    3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
    From these tests, I suspect the problem might be on the mainboard. Could anyone...
    08-24-2025, 03:47 AM
  • brithepi2k
    Samsung UE75TU7020k No picture, Standby blinks 2 times
    by brithepi2k
    My Samsung UE75TU7020k lights up fine when one of the ribbon cables are disconnected from the main board, lights stay on but not getting half a picture, I do the same with the other ribbon and put the other one in and lights stay on but not getting half a picture. The standby light flashes 2 times then reboots then it then tries to come back on again and just keeps looping until I take either one of the ribbon tables out (doesn’t matter which one I take out it stays lit when either one is out). I’ve tested the backlights but all working with none shorting out, I’ve replaced the main board...
    04-23-2025, 10:05 AM
  • Samunggg
    Samsung UN70NU6900FXZA - Red Light Blinks 2 Times Then Screen Flickers
    by Samunggg
    I've happened upon this TV, it came with no power cord or remote and it seems to be experiencing a common issue where the red indicator light blinks 2 times then the screen flickers as if it's trying to turn on. No picture, no sound. I suspect the functions of the TV are in good order and that the underlying issue is with the power button which is missing. It's just a white tab where the button should be which means I can't cycle it.
    I wanted to know if there is anything I can do or if I should just get a replacement module with the hopes it will fix the system. Alternatively if...
    09-06-2023, 06:39 PM
  • ronaldopdias
    Lenovo ThinkPad X1 Fold Gen 1 20RL000VUK
    by ronaldopdias
    Hi everyone.
    I got this Lenovo ThinkPad X1 Fold Gen 1 20RL000VUK from a customer that stated that his son was playing with BIOS settings and now it wont turn on. I guess the customer son was trying to update BIOS via windows and it shutdown while updating and it bricked this device.
    I've tried to find the BIOS firmware everywhere and nothing is available.
    Can anyone here help me to check if the firmware is corrupted and has a bios firmware for this model, please?
    It does not turn on, but when plug the charger the fan goes full speed and power button blinks 3 times. Sometimes...
    11-17-2025, 07:39 AM
  • mecha1166
    XR-77A80K Dead set, red light blinks 8 times. Cannot find error code list.
    by mecha1166
    I have a XR-77A80K here. When plug in & press power, white lindicator light flashes on & off. about 30 seconds later, indicator light flashes 8x red. Checked Sony, Power reset = unplug & plug in. Factory reset involves turning it on, then pressing remote buttons when a picture shows. Well, neither of these "resets" are for a dead set like this. Anyone know what 8 blinks indicates, from the schematic? Thanks!
    07-01-2024, 05:47 PM
