HP Envy 27 B210 AIO All-In-One Boot Problem
  • cheebster
    • May 2008
    • 373
    Hello! I have a problem with 2 machines, exact same model same issue.
    They are HP ENVY 27-b100 All-in-One Desktop, Model No.27 B210
    On bootup, they give both led and speaker beeps together, 3 long and 4 shorter beeps.
    The power supplies are original HP 200W, and i bought 2 replacement PSU's that give the same result
    Ram has been tried with or without, same result, and also tried a CMOS reset
    The main board is HP CONFIT L04815-601 L04815-001 tpc-t008-27 sch3730-6050a2960801-mb-01
    From this page;
    http://h10032.www1.hp.com/ctg/Manual/c06589940
    3 Long, 4 Short
    The system board displays a power failure (crowbar)
    1 Reduce to minimum config (CPU, Main-Board, PSU,
    Single memory DIMM) and isolate failed component.
    2 Reduce further if issue persists.
    3 Test known good PSU.
    4 Replace affected component.
    5 If unable to confirm source, replace CPU, Main-Board, PSU.
    So it seems the board has some issue, and it seems that it happens often, both units i have do exactly the same.
    Anyhow can help with this ? thanks
  • cheebster
    • May 2008
    • 373
    Re: HP Envy 27 B210 AIO All-In-One Boot Problem
    Would it be possible that my issue is a bios related issue, corruption or similar ?
    • cheebster
      • May 2008
      • 373
      Anyone ? Thanks
      • lustre
        • Jul 2021
        • 14
        Typically for similar symptoms on Dell motherboards, there's an auxiliary power rail that's not present like DDR_Vtt on DIMMs. Reflashing BIOS would be the easiest start but typically those beep codes are pretty accurate
        • cheebster
          • May 2008
          • 373
          So you mean that's really a power rail failure on the board, a component that failed ? I don't know where to start..
          • reformatt
            • Feb 2020
            • 1414
            Yep, probably a missing power rail during the power up sequence. What I normally do is measure resistance to ground of each coil, hopefully finding a short. Note that low resistance on coils near the CPU is to be expected (like 2 ohms or more). What you are looking for is a dead short on 3.3/5/1.05/1.2V rail.
            Unlikely to be a BIOS issue, you can try a CMOS reset by disconnecting the CR2032 battery and shorting the pins. Obviously do this with no power present.
            • cheebster
              • May 2008
              • 373
              Ok thank you. But how do i identify/find where are the rails to check without schematics ?
              • cheebster
                • May 2008
                • 373
                Hello. Anyone can give a tip on where to start on these? Thanks.
                • cheebster
                  • May 2008
                  • 373
                  I looked around the board and couldnt find anything visually, or checking everything i could with the meter. Here are pictures of the board, maybe some could chime in.. Thanks
                  • cheebster
                    • May 2008
                    • 373
                    Anyone ?
                      • 20977
                      Originally posted by cheebster
                      Anyone ?
                      Post the exact resistance measurements to ground of all the large grey square coils, on both sides of the board.Mark them on your pictures
                      • cheebster
                        • May 2008
                        • 373
                        With a fluke 115 set in ohm mode auto, i get all readings in MegaOhms and fluctuating either up or down. is that normal ? On each coil.
                        • cheebster
                          • May 2008
                          • 373
                          Anyone can help on this one ? Stuck with these 2 with the same symptom and can't fix them. I've tried poking around with the meter, but i would really appreciate some guidance. Thanks
                          • kodinabeel
                            • Sep 2014
                            • 63
                            • saudi arabia
                            any option you have
                              HP ENVY ENVY Desktop - 750-524 ENVY 750 i7-7700 Specification for Upgrade or Repair
                              This specification for the HP ENVY ENVY Desktop - 750-524 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ENVY ENVY Desktop - 750-524 boardview and ENVY ENVY Desktop - 750-524 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                              09-12-2024, 03:44 PM
                              HP ENVY ENVY Desktop - 750-510 ENVY 750 i5-7400 Specification for Upgrade or Repair
                              This specification for the HP ENVY ENVY Desktop - 750-510 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ENVY ENVY Desktop - 750-510 boardview and ENVY ENVY Desktop - 750-510 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                              HP ENVY x360 ENVY x360 - 15-dr1011na Hybrid (2-in-1) 15 Specification for Upgrade or Repair
                              This specification for the HP ENVY x360 ENVY x360 - 15-dr1011na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 - 15-dr1011na boardview and ENVY x360 - 15-dr1011na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                              09-06-2024, 12:18 PM
                              HP ENVY x360 ENVY x360 Convert 15-ds0502saBundle 6TD07EA Hybrid (2-in-1) Specification for Upgrade or Repair
                              This specification for the HP ENVY x360 ENVY x360 Convert 15-ds0502saBundle 6TD07EA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 Convert 15-ds0502saBundle 6TD07EA boardview and ENVY x360 Convert 15-ds0502saBundle 6TD07EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                              09-06-2024, 11:17 AM
                              HP ENVY x360 ENVY x360 Convert15-dr1013na 7PW22EA Hybrid (2-in-1) Specification for Upgrade or Repair
                              This specification for the HP ENVY x360 ENVY x360 Convert15-dr1013na 7PW22EA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 Convert15-dr1013na 7PW22EA boardview and ENVY x360 Convert15-dr1013na 7PW22EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
