Hello colleagues:
I have in my bench an Apple iMac A1311 (21,5¨), which is driving me nuts.
The machine starts when you push the power, the chime sounds, the Apple logo appears, even the progress bar appears, but when the bar is around the 40% , the machine goes black and restarts by itself. And this is a loop.
Things that I've made:
-The screen presented pink vertical bars. I have done a VGA chip reballing. Succeed. No bars. Clean screen at startup. This problem is solved.
-PRAM resetted. Same results.
-RAM checked and sockets cleaned. No beeps. OK.
-Try to start up the machine from another good verified USB SSD disk, with El Capitan inside. Pressing ALT at startup it presented all possible startup volumes, all correct. I have chosen the external one. Nearly same results (this time the screen goes white forever, no restarts, but it does not work nor load system).
-Tried system recovery thru internet, connected via ethernet. The machine connects (you can see the earth globe), but suddenly white screen and restarts.
-Tried to start it up without internal hard disk, and as before, with an external USB drive, this time with two different units, El Capitan and Sierra. Same results.
-Internal (mechanic) HD extracted and checked with Disk Utility and Disk Warrior. Perfect. Zero problems. Even I started a Mac Book Air with it.
-Startup using Apple Hardware Test (AHT). It tolds me it has an error (4SNS/1/40000000: TH00-9.000). It seems to be a thermal sensor, but all sensors are present, and seems to be fine. Except when I removed the internal HD, of course; when you do this, you remove the HD thermal sensor when you remove the HD.
-Of course, CMOS battery checked and changed.
-I was told by the owner the machine was working perfectly until this suddenly happened (included the pink vertical bars in the screen, which leads me to think it probably was a video card problem).
I'm really lost. This is the very first time I have such a problem. Before, I always be able to start any Apple with an external drive.
Any help will be greatly appreciated.
