HI I have a PC using a Corsair cx600 psu & ASRock B450 Pro4 mother board that won't power on after a shutdown (replaced a dead drive in a raid array) Not the boot drive.
With most things unplugged, including the 24 pin ATX connector, but not the ATX12v to cpu, I have +5.01V on the +5vsb pin 9 from the PSU. When I plug the 24 pin back in to the mobo, the +5vsb fluctuates between 1.1v & 1.9v.
Not sure where to go from here ?
Is the PSU at fault or is the mobo causing the problem
Look forward to any help :-)
If I plug the 24 pin ATX connector into the mobo - with the ATX12v to CPU not plugged in - then I still get +5.01v on the +5vsb at the 24 pin connector
PSU will start up while PS_ON is shorted to Gnd
