So network capabilities is definitely a requirement in our home.... with me having my hands in so many things, I don't have the time to deal with the troubles of networking. At the same time, I don't own, so I cannot go pulling wire for a backbone. Because of this, I took what I had and expanded on it.
Over the last 6 years, I've used apple Airport Extremes. Some of you may cry and shout, but the truth is that they have simplified the process to an effortless setup and their wireless bridging just works.
Now that I'm able to get 400 x 20, it was time to do an upgrade. PS4 and IPTV, and multiple web and file servers, my network needed an upgrade. So, here's what I did.
Well before I jump right into it, there's some back story. When I established my account, the technician decommissioned every line in the house. Why? Because they think it will cause interference! What a load of BS! After fighting with them about this, the tech documented my account about the dispute and stated that if lines were reconnected that I would be subject to all costs related to any trouble ticket at my location and any neighbors if determined that my doing so was the cause. My response, "OK, you want to tell me how to hook up my house... so be it. Your job stops at the modem!"
Recently I had an issue with the ISP that took 12 visits over a period of 2 weeks to get them to identify and address my bandwidth being an average of 12 x 20 and merely peaking at 50 for a second. Turns out they had the main circuit oversubscribed (I tried to tell them but since I don't work for them, I must not know what I'm talking about). It only took a plant engineer to spend his day here to figure it out. Sadly for him, he spent the whole day while I was at work managing my own enterprise subscriber based network. When I got home, I explained everything to him, showed him the logs questioning why I was being routed from one city to another then back again, and then a completely unusual route to the mid country (MS) all to get routed back to ATL when ATL is a straight route from me. After showing them this, and the other iperf logs, I reiterated load balancing and routing policies. Sure enough they figured it out. Its a shame it took them so long as this issue affected the entire city!!!
OK so back on track, this new bandwidth and also the issues above contributed to my upgrade and configuration
My configuration is as follows.
Line to house >> box on house >> direct line to modem (end of ISP circuit)
Modem >> EdgeRouter >> PfSense on the side as transparent monitor (separate machine) and a Pi running PiHole for DNS and ad-blocking.
EdgeRouter >> MoCA adapter >> box on house >> separate MoCA compatible splitter >> rest of house
rest of house :
box on house >> MoCA adapter >> Airport Extreme in AP mode (Living room)
box on house >> MoCA adapter >> Airport TimeCapsule in AP mode (Den)
box on house >> MoCA splitter >> MoCA adapter >> Airport Extreme in AP mode (office)
box on house >> MoCA splitter >> MoCA adapter >> Airport Extreme in AP mode (master)
The other perk to me using the Airports is that each gives me an additional 3 ports to use for hardline connection.
In the den I have my Synology, PS3, PS4, Sony home theater, and my "entertainment box" all hardwired.
In the office, I have my main workhorse computer, my secondary node, my openhab controller, and my pi.
I have full signal for most of my cul de sac, my max ping internal is 18ms wheras my external is 24ms. I get full 400 x 20 hardwired and by WiFi but the other nice thing is my Airports support a "Guest" WiFi. Well this "guest" is now the everyday use wifi, and the primary is reserved for me as I work with some heavy files.
Everything works beautifully! I don't have to compete with friends, family, guests, misc. smart devices that are all on the "guest." My media is fully accessible as that "guest" wifi is a hidden VLAN used by Apple. So had to make the pinhole for it to get through.
I have DPI running, Snort and pihole. I also can enjoy 4K locally on every TV without a hiccup in the network.
Since my setup, the ISP has followed up 3 times to "check on things." The first time was the same tech that marked up my account during the initial install. When he called his supervisor and the sent a picture to the Engineer, they were told the same thing I said, the line to the modem is dedicated and separate. Your responsibilities stop there.
Along with this, because of the beauty of my setup, there are no additional holes, wires, etc. and I can take it down in a flash without a trace. Pretty sweet!
rest of house :
