Netgear GS108: Is Defect Bad Caps?
  • bgavin
    • Jan 2007
    • 1355
    There is a huge amount of negative feedback on the Newegg site for various GS1xx gigabit switches.
    The Netgear mouthpieces replies there is a "manufacturing defect" that was resolved in 2007~2008, and late model devices should not have it.
    My question: has anybody found this to be bad caps?
    The Netgear customer support, and lifetime warranty, is pure shit.
    I've been down the road with the Folks From Bangalore, and the amount of wasted time, plus costs of shipping, make a new unit about the same as an RMA.
    I don't mind recapping a new GS108 and tossing away the warranty, if that is the cause.
    Anybody?
    by momaka
    03-12-2025, 03:42 PM
  • eryjus
    by eryjus
    05-10-2023, 11:21 AM
  • Paxman_Swede
    by Paxman_Swede
    Hello!
    01-14-2025, 09:51 AM
  • captain150
    by captain150
    03-16-2025, 07:34 PM
    EVGA e-GeForce 7600 GS AGP 256MD2 [256-A8-N542-T2] with bad caps - fixed
    by momaka
    I did it again – I had to fulfill my inner desire to fix yet another old piece of hardware. This one is actually kind of worthwhile, too – it’s an EVGA e-GeForce 7600 GS AGP video card, model P/N: 256-A8-N542-T2. With the popularity of “retro” PCs from the Win9x to XP era going up, and the diminishing supply of decent AGP cards, it is expected their prices will go up. Or is it? I bought the this video card rather on the cheap side (~$9 USD shipped to my door), because the eBay seller listed it for parts or repair (and correctly noted the bad capacitors.)
    So, here is the...
    06-06-2020, 04:39 PM
