Wireless card not picking up all wireless networks?
  • japlytic
    • Oct 2005
    • 2086
    Despite being within range of a wireless network and it is still not being picked up, check the Region setting (Advanced Options) in Device Manager for the wireless networking device in question and set it according to your country.
    In a number of cases, the default Region is set to US (Channels 1-11).
    Also, check the 20/40 MHz setting (if available) and change it to from 20 MHz Only to Auto and do the same on the wireless access point you own to help enhance performance.
  • desert-rat
    • Mar 2014
    • 4103
    Re: Wireless card not picking up all wireless networks?
    I got a alfa u.s.b. antenna, it picks up just about all the wifi sig.s around.
    • diif
      • Feb 2014
      • 6978
      • England
      It depends on the band/technology you're using.
      Any 2.4Ghz wireless (b,g and n) is susceptible to interference from microwaves, baby monitors, video streamers, cordless phones and the like.
      The optimal channels to be on are 1, 6 and 11. However it depends what you're neighbours are on.
      Switching to 5GHz technology (n and ac) will help alleviate interference/connection issues.
      • japlytic
        • Oct 2005
        • 2086
        The problem I am talking about is not related to other 2.4 GHz wireless devices and microwave ovens.
        I forgot to mention that the access point in question which was not being detected by a particular computer (but all others devices detect it OK) was set to Channel 13 (primary 802.11n channel; secondary is Channel 9 for the same radio - the wireless client will only detect a wireless network on a primary channel); the typical default for a wireless client which driver installation cannot sense regional settings is Channels 1-11 (US).
        For the 2.4 GHz band, Australia allows use of Channels 1-13 on wireless network access points; optimum channels (per 20 MHz wide stream without the use of 802.11b devices which use a slightly wider stream) are 1, 5, 9, and 13.
        • diif
          • Feb 2014
          • 6978
          • England
          Its 1, 6 and 11 if you don't want channel overlap.
          I've seen issues with PCs with their metal cases causing issues with wireless.
          • japlytic
            • Oct 2005
            • 2086
            Per channel/stream, Wireless-B is 22MHz wide and Wireless-G and Wireless-N is 20MHz wide.
            • diif
              • Feb 2014
              • 6978
              • England
              N is 40MHz wide if its on 5GHz.
              • desert-rat
                • Mar 2014
                • 4103
                I thought all the wifi antennas that covered the 5 Ghz band also covered the the 2.4 , but I may be wrong . This is that alfa .
                http://www.amazon.com/Alfa-AWUS036NH...&keywords=alfa
                • japlytic
                  • Oct 2005
                  • 2086
                  This is correct for Wireless-N 300 mode if 40MHz channel width mode is selected (automatically or manually).
