Linksys SD2008
    Linksys SD2008
    I have a gigabit 8 port switch with (4) Stone 470uf 25v 105 deg C caps that are bad & (2) stone 1000uf 25v caps 85 deg C. I read a forum where a guy replaced them with Nichon 820uf 16v poly for the 1000uf & 270uf 16v poly for the 470uf, the input AC adapter is 12vDC. Will these work out for this application, or should I stick with electrolytic's?
    Bruce
    Re: Linksys SD2008
    They'll work, but it would be a waste of money.
    Electrolytic capacitors from good manufacturers would work.
    Use Panasonic FM or FR, Nichicon HE, UCC KZE, KY, etc, Rubycon ZL* ... digikey.com has plenty of them.
      Re: Linksys SD2008
      TY Mariushm. Kinda thought so but had to ask!
        Re: Linksys SD2008
        for the 470uf I'm looking at 667-EEU-FR1E471 from Mouser
        & for the 1000uf I'm looking at 667-EEU-FM1E102 from Mouser.
        Does that look good?
          Re: Linksys SD2008
          Sure, no problem. Much better than those stone capacitors.
