Linksys EF2S24, V2 not working
+ More Options
Posts
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    once it is plugged in the power/LAN lights all go on, then off, then on, then off, then on, then off, very rapidly. You get the point.
    On the connector from the power board to the main PCB, (analog multimeter black probe on black connector, red probe on red connector), it bounces up and down at about 1 volt. No visible bad capacitors. Ideas?
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Linksys EF2S24, V2 not working
    Pictures of the board would help.
    --- begin sig file ---
    --- end sig file ---
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      I've attached a picture of the power supply.
      The secondary caps are Ltec. 2x 2200uF 10V and 2x 1000uf 10V. Even though they look fine, is that the first thing I should do, replace them?
      Please look at picture and advise :-)
      Oh and there is a slight click, click, click coming from the PSU.
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        You posted while I was uploading the picture... it should be working now!
        • retiredcaps
          • Apr 2010
          • 9271
          That is the PSU trying to startup.
          I would suspect either
          1) bad SMPS chip (IC1)
          2) bad electrolytic startup cap (the one between IC1 and IC2)
          • retiredcaps
            • Apr 2010
            • 9271
            3) Measure the DC current across that startup cap. Is it steady or fluctuating?
            4) What is the part number of IC1?
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              The little Taicon 47uF 25V? Should I try to replace that?
              • shovenose
                Send Doge Memes
                • Aug 2010
                • 6575
                Would either of these be suitable for using to replace it? (I don't ahve that exact one):
                Hitano 22uf 50v
                Fuhjyyu 10uf 50v
                nichicon 100uf 16v
                Samxon 680uf 16v
                Thanks!
                • retiredcaps
                  • Apr 2010
                  • 9271
                  1) Did you see post #6?
                  2) Get the right cap. 47uF 25V is fairly common cap in PSUs (more likely 47uF and 50V).
                  • shovenose
                    Send Doge Memes
                    • Aug 2010
                    • 6575
                    Sorry, I missed Post 6. I will check that cap tomorrow.
                    I would like to use a cap from my collection. If I ordered online it would be stupid for 1 cap, and if I were to get it local I would have wait until next Saturday. And I'm not patient enough for that.
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      For test purposes, you can take an used cap from a PSU. If it works, then order the proper cap with your next order.
                      • shovenose
                        Send Doge Memes
                        • Aug 2010
                        • 6575
                        That's a pretty good idea... even though knowing me I would never get the right cap (I would leave the test cap in there )
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          Members who live in the USA all report that if you order from digikey, it takes about 2 days using United States Postal Service 1st class mail to arrive. Additionally shipping is around $2.75.
                          • shovenose
                            Send Doge Memes
                            • Aug 2010
                            • 6575
                            Shipping of almost $3 for a single tiny part? loL!
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              Very reasonable when considering the cost of gas and time. However, I do balk at $8 USD shipping to Canada. I generally save up for a big order to ammortize the shipping costs.
                              Unfortunately, any order over $20 USD gets dinged by Canada Customs for tax, GST, etc.
                              • shovenose
                                Send Doge Memes
                                • Aug 2010
                                • 6575
                                Important new discovery:
                                I put the power board sideways to get easier access to the measuring of the startup cap. Well, it did the clicking thing a few times then it fired up and STAYED ON...
                                I plugged in an ehternet cable and it seemed to work!!!
                                Why? What does this mean?
                                I'm uploading a video right now, just a sec...
                                OK you can download the video here:
                                http://img256.*************/img256/975/ff9.mp4
                                (I use VLC to play those files)
                                • mariushm
                                  • May 2011
                                  • 3799
                                  Maybe bad soldering? Inspect the back side of the board especially near the TO220 chips (the ones with three leads) and the bridge rectifier the rectangular thing on the left of the large transformer.
                                  Also, as you mention clicking... that could be from a relay and it just so happens that white rectangular thing in the lower left corner looks like a relay and the two wires going into the socket near it seem to come from the mains.
                                  The relay may be bad or the soldering at the bottom may be bad (could be due to some short that fuse didn't protect it from)
                                  Inspect the back side and report.
                                  • shovenose
                                    Send Doge Memes
                                    • Aug 2010
                                    • 6575
                                    The soldering looks great. However, when I shake the thing, there is a rattling sound. I think it's coming from that corner. Might that have something to do with it?
                                    By the way, I screwed it back down and now it seems to work. But, it does do the clicking thing once or twice before starting up, about half of the time when I plug it in...
                                    That white rectangular thing is marked CX1. I think it's an X capacitor on the input filtering.
                                    • shovenose
                                      Send Doge Memes
                                      • Aug 2010
                                      • 6575
                                      Alright new progress: I bend the startup cap a little to the side so I could measure the legs.
                                      Bounces up and down while it flickers on and off. Voltage seems to bounce around near 12V
                                      • shovenose
                                        Send Doge Memes
                                        • Aug 2010
                                        • 6575
                                        To re-summarize:
                                        The "starup cap" that was mentioned previous does have the voltage bouncing up and down while the power cycles on and off rapidly. Would that suggest that it's something on the primary (before the startup cap?)
                                        I'm still interested in fixing this.
                                        Please help.
                                        Thanks!
                                        • 5mall5nail5
                                          Help identifying connector for ASUS 4090 Strix RGB LED connector
                                          by 5mall5nail5
                                          Hi All -
                                          I had replaced my ASUS 4090 Strix cooler with a waterblock and put the stock cooler on the shelf. Was moving it and snagged my sweater on the connector and pulled the wires out of the pins on the RGB connector. I tried to get them back on but its too small so I opened the stamped pins and tried to solder but its not a good repair and the wire broke on reinstallation.
                                          Looking to replace the connector on the cable side and get pins to crimp onto a new cable. Bought random JST and such but nothing is correct. Can anyone help identify the connector and possibly matching...
                                          05-04-2025, 07:47 AM
                                          HP EliteBook 850 G6 + Linksys Velop Intelligent Mesh WiFi System Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 850 G6 + Linksys Velop Intelligent Mesh WiFi System Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 850 G6 + Linksys Velop Intelligent Mesh WiFi System boardview and 850 G6 + Linksys Velop Intelligent Mesh WiFi System schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
                                          09-06-2024, 07:50 PM
                                          HP EliteBook 830 G6 + Linksys Velop Whole Home Mesh Wi-Fi System Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 830 G6 + Linksys Velop Whole Home Mesh Wi-Fi System Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 830 G6 + Linksys Velop Whole Home Mesh Wi-Fi System boardview and 830 G6 + Linksys Velop Whole Home Mesh Wi-Fi System schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
                                          HP EliteBook 830 G6 + Linksys Velop Intelligent Mesh WiFi System Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 830 G6 + Linksys Velop Intelligent Mesh WiFi System Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 830 G6 + Linksys Velop Intelligent Mesh WiFi System boardview and 830 G6 + Linksys Velop Intelligent Mesh WiFi System schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
