LG 22W2234S troubleshooting and spare parts
  • munuainen
    • Jul 2010
    • 40
    Re: LG 22W2234S troubleshooting and spare parts
    Mosfets arrived. Unfortunately the seller had sent AP2761s instead of AP2763s. Upon contacting the seller said the two mosfets should be interchangeable. I'm not quite sure if that's the case. Maybe someone here is competent enough to clarify? I tried installing one and this time nothing blew up but there were no signs of life in the monitor either.
    AP2761: http://www.a-power.com.tw/ProductDetails.asp?M_ID=154
    AP2763: http://www.a-power.com.tw/ProductDetails.asp?M_ID=157
    • jetadm123
      • 2169
      Looks like the 2761 is a higher amperage (10A vs 8A)/lower voltage than the 2763 (650V vs 750V).
      1) Is the body of the 2761 all plastic like the 2763? In other words, is the tab of the 2761 you screwed onto the heatsink made of metal or plastic?
      2) Since you already intalled the 2761, for testing purposes, are you still getting the proper voltage across the main cap?
      3) Check the VCC (pin 7) of the LD7522. What is it?
      • munuainen
        • Jul 2010
        • 40
        1) Yes, its plastic all over.
        2) Around 320 V which I assume is a healthy reading.
        3) I'm getting a steady 86 V. I suppose that can't be good as the supply voltage should be 30 volts, right?
        • retiredcaps
          • Apr 2010
          • 9271
          Originally posted by munuainen
          1
          According to datasheet, it should be 30V maximum for VCC. I suggest rechecking your resistor values to make sure you have the right ones.
          --- begin sig file ---
          --- end sig file ---
          • munuainen
            • Jul 2010
            • 40
            I also thought the change in voltage must be due to resistors. However, all resistor values in the pcb section related to LD7522 seem fine to me (measured off-circuit). See the attached image for details.
            • retiredcaps
              • Apr 2010
              • 9271
              #26
              See if d803 is shorted?
              • munuainen
                • Jul 2010
                • 40
                #27
                Nope. All three diodes in the proximity give one-way reading only.
                • munuainen
                  • Jul 2010
                  • 40
                  #28
                  Just thought this might be worth mentioning if it helps with pinpointing the culprit. I plugged in the power to measure voltages on different spots when another bomb hit, killing the mosfet and the two largest resistors. This time it wasn't due to probe shorting.
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    #29
                    Well, I suggest starting at the very beginning then. Obviously, something is blowing out the circuit. Follow these instructions by Krankshaft and see what component is possibly shorted.
                    https://www.badcaps.net/forum/showpo...15&postcount=2
                    • munuainen
                      • Jul 2010
                      • 40
                      #30
                      Line fuse fine.
                      The thermistor RT801 should be 4.5 ohm according to the data sheet . I'm getting almost 11 ohms off-circuit at room temperature.
                      Line rectifier. Again, unstable readings. Several hunder Kohms anyway.
                      Line filter cap charging up.
                      Mosfet I cannot really check, can I? One is dead, the other I don't want to sacrifice.
                      Output rectifiers are located further up the pcb. Do they really matter at this point?
                      By the way, when I checked VCC voltage I compared voltage from pins 7 (VCC) and 5 (GND). Pin 5 is directly connected to the minus output pole of the rectifier which obviously is different from the AC connector ground. Did I do right? The reading I got from the pin 5 and AC connector ground before resistors and the mosfet blew up was around 15V.
                      Gosh I'm such a n00b. I should probably set time aside to study electromagnetics.
                      • jetadm123
                        • 2169
                        #31
                        It looks like cap c808 is across the Drain and Source of mosfet q804 (please verify this). If this cap shorts, it provides a direct path to R815 (the 2W resistor). Since q804 is shorted, you will probably have to remove c808 to check it.
                        • munuainen
                          • Jul 2010
                          • 40
                          #32
                          C808 definitely not shorted. I'm getting a reading around 1,5Mohm in-circuit, blown mosfet and large resistor having been removed.
                            HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                            This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                            09-12-2024, 02:20 PM
                          • Jaime Morillo
                            Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                            by Jaime Morillo
                            Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                            The TV was stuck on the logo and I couldn't access the update menu.
                            I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                            The image result was good, but the image is inverted.
                            The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                            Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                            08-18-2025, 11:38 AM
                            HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                            This specification for the HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load, Asset Tag & Testntag boardview and 430 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                            09-06-2024, 10:56 AM
                            HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                            This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                            HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook 1000 Specification for Upgrade or Repair
                            This specification for the HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load & Asset Tag boardview and 1050 G1 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
