Lenovo ThinkVision L191 19" goes blank after <1 sec
  • jonathanku
    Keen Tinkerer
    • Jun 2010
    • 32
    Re: Lenovo ThinkVision L191 19" goes blank after &lt;1 sec
    Thanks for that. Here's a higher quality pic of power/inverter board.
    Please see attached image - (2000 px wide)
    • el3ctroded
      • Nov 2008
      • 198
      Some other things to check that are real quick tests:
      Check for shorts on all pins of Q203, Q206, Q207
      Do diode test on D201
      J921: I think this is it's designator, hard to tell. But it looks like it isn't well-connected on the bottom of the pcb because of maybe being made too short. It's a long wire jumper next to Q203 and Q207. Make sure it's making good connection.
      Better pic of the top of the psu plz.
      • PlainBill
        • Feb 2009
        • 7034
        Pin 10 of IC201 controls the power to the Royer oscillator. What is it's voltage after the backlights turn off. Also, it appears the feedback from the current sensing caps goes to pin 3 of IC 201. Please verify the top of R232 goes to pin 3 of IC201.
        PlainBill
        • jonathanku
          Keen Tinkerer
          • Jun 2010
          • 32
          No shorts on these.
          I'm not too sure what to expect for the diode - the meter's diode setting says 2k, and the two readings I got were:
          0.266
          0.729
          I'm not sure of this one. I can see the J921 label on the rear of the board, but not sure which connection to check. On the front of the board, there looks to be a space for a connector, but with nothing there (just the white printed line).
          See attached.
          • jonathanku
            Keen Tinkerer
            • Jun 2010
            • 32
            I'm getting 0.09. Note I opted to put the other probe on one of the four nodes to the left of the screw-hole by the RoHS logo. Is that suitable?
            Yes it does.
            • el3ctroded
              • Nov 2008
              • 198
              J921 wasn't used, so don't worry about that. In the old pic I couldn't tell it wasn't there.
              D201: Your reading depends upon the type of diode used. This was probablly a schottky, so around 0.2 to 0.3 is good. However you shouldn't get reading both directions, but sometimes circuitry makes readings not as expected. Since you got readings in both directions, you will have to de-solder one side of the diode and re-do the test.
              • PlainBill
                • Feb 2009
                • 7034
                Yes it does.
                That was fine. I'm going to give you the Cliff's Notes version of what is going on with this circuit.
                The return lines from the 4 CCFLs go through resistor - diode networks that charge C223. The voltage on C223 is dropped by diode D210 , further reduced by R231 and R232, then goes to IC201, pin 3. The threshold for this is IC201, pin 4. If pin 3 is at a lower voltage than pin4, the controller shuts down the output.
                The easiest way to troubleshoot would be by forcing the CCFLS on, but I REALLY hate disabling the feedback loop, so we will proceed in another direction.
                1. Measure the resistance across R225, R226, R227, and R228. The should be identical.
                2. Set your DMM on the diode test scale and measure the voltage drop on D202, D204, D206, and D208. The should be the same.
                3. Also measure the voltage drop on D203, D205, D207, and D209. Again, all four should be the same.
                4. What is the voltage drop on D210?
                PlainBill
                • jonathanku
                  Keen Tinkerer
                  • Jun 2010
                  • 32
                  #28
                  Hi again, interesting info. And you're spot on.
                  1. R225, R226, R227, and R228 are 0.98, 0.97, 0.98 and 0.97 on the 20kΩ scale.
                  2.
                  D202: 0.780 / 0.866
                  D204: 0.780 / 0.860
                  D206: 0.780 / 0.863
                  D208: 0.786 / 0.867
                  3.
                  D203: 0.870 / 1.789
                  D205: 0.863 / 1.781
                  D207: 0.862 / 1.783
                  D209: 0.865 / 1.785
                  4.
                  D210: 0.900 / 1. (this is how the meter displays it... though "1." is also displayed when the probes aren't on anything with the diode setting - I'm fairly confident they were contacting ok)
                  • PlainBill
                    • Feb 2009
                    • 7034
                    2.
                    D202: 0.780 / 0.866
                    D204: 0.780 / 0.860
                    D206: 0.780 / 0.863
                    D208: 0.786 / 0.867
                    3.
                    D203: 0.870 / 1.789
                    D205: 0.863 / 1.781
                    D207: 0.862 / 1.783
                    D209: 0.865 / 1.785
                    4.
                    The resistors match, but I hadn't really expected a problem there. D208 has a very slightly higher voltage drop; still it's within 6 millivolts, not likely to be the problem. Those all look fine.
                    On the other hand, the D210 reading does NOT look right. Most DMMs apply 2 Volts through a resistor across the leads on the diode test scale and display the actual voltage. As far as I know, a small signal diode should NEVER have a .9 volt forward drop with such low current. If you have a high speed switching diode such as a 1N4148, try soldering it across D210. Otherwise, try a resistor in the range of 1K to 10K if you have one available. If neither of those are available, try shorting across the diode.
                    If you use a resistor or a jumper, only try it for a few seconds - just long enough to verify the backlights are not shutting down. I don't want to risk damaging anything.
                    PlainBill
                    • jonathanku
                      Keen Tinkerer
                      • Jun 2010
                      • 32
                      #30
                      el3ctroded - I've not yet de-soldered one side of D201, I'm not the most confident at desoldering and resoldering, but will if it's necessary...?
                      In the mean time, I've done PlainBill's test and shorted across D210 (didn't have any resistors handy) and this did allow the monitor to remain on. I left it for about 5 sec - definitely longer than it used to stay on. Does that mean D210 is the problem, or just an indicator of another problem?
                      Thanks. -JK
                      • jonathanku
                        Keen Tinkerer
                        • Jun 2010
                        • 32
                        #31
                        Here's D210 close up.
                        If this needs replaced, any idea on the type/rating etc.?
                        • el3ctroded
                          • Nov 2008
                          • 198
                          Don't worry with D201, obviously not a problem
                          D210 should be replaced with any of these: 1n4148 or 1n914 or 1n4448
                          • PlainBill
                            • Feb 2009
                            • 7034
                            The real test would be to unsolder it and perform the diode check out of circuit. As I said earlier, the forward voltage drop seems to be too high. Perhaps someone else has more experience with 'reading' these diodes.
                            Radio Shack # 276-1122 is a package of 1N914 / 1N4148 diodes. I would suggest picking up one,, and performing three tests.
                            1. Check the forward voltage drop of one of the new diodes with your DMM. I would expect a reading of about .7 volts.
                            2. Check the voltage drop of the original diode. If it reads open in both directions it is definitely bad.
                            3. Replace D210 with one of the new diodes (yes, you will have to be slightly creative installing it). Then test the monitor. I'd watch it carefully for the first ten minutes of so for any sign of problems, then take it in steps before reassembling it.
                            PlainBill
                            • jonathanku
                              Keen Tinkerer
                              • Jun 2010
                              • 32
                              #34
                              Excellent. I'll do these tests - it'll need to be tomorrow - and check local suppliers for a replacement.
                              • jonathanku
                                Keen Tinkerer
                                • Jun 2010
                                • 32
                                #35
                                Well, unfortunately, the diode crumbled as I removed it. Either I was too heavy-handed, or it already had physical flaws - I don't know.
                                I'll get a replacement (i.e. one of these from maplin.co.uk tomorrow (Mon) as I work near one of their stores.
                                • PlainBill
                                  • Feb 2009
                                  • 7034
                                  Odds are it had already cracked. That's why the inverter wasn't working.
                                  PlainBill
                                  • jonathanku
                                    Keen Tinkerer
                                    • Jun 2010
                                    • 32
                                    #37
                                    OK, not sure what's going on. I got a 1N4148 from Maplin and soldered it in temporarily in place of D210 (making sure the black band was at the same end as the old D210), but got the same 2 sec to black behaviour.
                                    I measured the diode in place and was getting the open reading in one direction ("1.") and 0.8ish (didn't record it) in the other direction.
                                    Having taken it out the circuit again, I measured the diode and got the same, "1." and 0.899. I'm now kicking myself for not measuring the readings before connecting it and switching on. Could I have blown that diode?
                                    • el3ctroded
                                      • Nov 2008
                                      • 198
                                      1. is what you meter reads when not connected right? Diodes should read nothing in reverse polarity, which is what you got.
                                      The diode seems to be reading high though. Did you only buy 1?
                                      • jonathanku
                                        Keen Tinkerer
                                        • Jun 2010
                                        • 32
                                        #39
                                        Yeah - 1. is the diode reading when not connected. And yes, I only bought 1.
                                        I have noticed though, that this is the same reading as I had with the old diode. But if they both blew when connected to the monitor, that might explain it - assuming there's a different root cause. I'll get another couple tomorrow and test them both before connecting them to the circuit.
                                        • el3ctroded
                                          • Nov 2008
                                          • 198
                                          Lets make sure none of the resistors in that circuit have failed (usually will go open circuit). Measure resistance of R232, R231, R230, R229.
