MSI Optix Monitor--Functional but no image
  • DoorOfTime
    • Jan 2017
    • 18
    I just picked up this MSI Optix MAG271C curved monitor. It powers on, backlight comes on and it's recognized by Windows--even as far as to be able to use the speaker port for music. It recognizes input changes, and goes into standby as intended when disconnected.
    But it has no image whatsoever. On power-up it goes through what should be an "MSI" splash screen, but no image, and when hooked up as a secondary monitor I can drag items across my extended display with no change as it reaches the blank monitor.
    Does this sound like behavior that can be resolved by replacing the main board? I've never encountered another device that was otherwise completely functional that didn't at least have some sort of shadow image, lines, etc. Is it possible this is because of a bad panel?
    by momaka
    03-15-2023, 10:17 PM
  • 3D Modelka
    AOC 27 monitor Q27G2WG4 doesn't display logo or image on screen
    by 3D Modelka
    Hello. I have a problem with my AOC 27 monitor, specifically model Q27G2WG4, which I have been using for 3 years. The monitor stopped turning on: when I turn it on, the backlight turns on, the indicator starts glowing white, but the logo on the screen does not appear, and there is no image. However, if I check in the Windows system, the monitor is displayed as connected and working. I tried connecting it via HDMI and DP, but the result remains the same. If I turn the monitor on and off multiple times, it will eventually start and work. However, when the monitor is working, there are no issues....
    02-09-2024, 02:42 AM
  • Coguar
    HP ProOne 23.8 inch G9 ALL-in-One Desktop PC - Working when plugged to an external monitor, no image otherwise
    by Coguar
    In the device manager there is no built-in display located. The Intel UHD Graphics are displayed and only the external display is visible. The AiO turns on and works but is only showing a black screen on the monitor.
    I checked the voltage on the backlight connector and it reads ~20V. I tried reseating the LVDS and Backlight connector, yet the image still does not show.
    Does anyone have ideas whether or not this is a BIOS related issue? The only visible log in the BIOS logs is that the firmware was updated around a month ago.
    We already tried to fix it by resetting the...
    06-23-2025, 07:14 AM
  • Madoy104
    Macbook Pro A1989 - No image, working fine with external monitor
    by Madoy104
    I have a MacBook Pro A1989 that was likely exposed to liquid. It doesn't display an image on the built-in screen, but the screen is backlit (you can't see the Apple logo or any other elements when held up to light). The laptop provides 20V and 1.5-2A, and it works fine when I use it with an external monitor. Currently, the connector for the display (J8500) is disconnected. I'm writing to ask for help in diagnosing the issue. I've heard that when the J8500 is exposed to liquid, the processor pin responsible for the display might short-circuit, and I'd like to know...
    08-15-2024, 10:01 AM
  • wattage
    by wattage
    Hello Badcaps Community,
    07-13-2025, 04:41 PM
