Samsung 172N different problem
  • smason
    • 1652
    Initial symptom was no power.
    Caps looked ok, but were Capxon so I replaced all power supply/inverter caps with Panasonic FMs.
    While testing, all voltages were fine, just wouldn't power up. Touched scope probe to one of the inputs from the control pcb, and it came on.
    Monitor works fine except none of the controls work, including the power button.
    I don't get how it's supposed to work. The control pcb has 6 switches on it, and a few LEDs and a bunch of resistors. No chips or transistors.
    There are only 2 inputs from the control pcb to the MCU. (part of main board schematic attached) I don't have a schematic for the control pcb.
    The switches all test ok, and continuity from the control pcb to the
    mainboard is good. I will probably test the zeners out of circuit this week.
    Will post some photos tomorrow or Tues.
    Any ideas?
  • PlainBill
    • Feb 2009
    • 7034
    Re: Samsung 172N different problem
    Any ideas?
    This is a fairly common design. There are several resistors in series on the control pcb. The form a voltage divider network between +5V and Gnd. So, for example, if you press the 'menu button', 3.6 volts will appear on KEY2. The input button might produce 1.8 volts on KEY2, etc. So you troubleshoot by pressing buttons and seeing if any produce voltage changes. If none do, you start looking for broken wires, cracked traces, etc.
    PlainBill
    • smason
      • 1652
      Ahh (cue the light bulb going on) Thanks Bill!! As usual you are a fountain of useful knowledge.
      I'll do some measurements tonight and report back.
      • smason
        • 1652
        I tried measuring the voltage of the key1 and key2 inputs while pressing buttons, there was no change.
        After a magnified visual inspection of the control board I spotted questionable solder on one of the resistors, so I touched up a couple.
        I managed to accidentally remove one (when you WANT to remove one it's not easy, go figure) I've always prided myself on having good soldering skills but this tiny surface mount stuff is nasty. I also used to pride myself on my excellent eyesight, but 50 is in the rear-view and I cant se s41t up close any more...
        When attempting to re-install the resistor my tweezers went "ping!" and there it was - gone.
        So I'll have to acquire a 150 ohm resistor before I continue. None of my donor devices seem to have that value. I s'pose I could graft in a regular 1/4 watt for test purposes....
        • smason
          • 1652
          Well I have to clean up my temp work area, so this one goes on the back burner for a while. Besides there's only so much time I can waste on a 17"....
          If I can get my normal work area cleaned up, there are more on my pile that deserve more attention, particularly the Gateway 2185w which *should* just be 8 caps, it looks to be in pristine physical condition.
          And a couple BenQs which *should* be solder joints and transistors.
          If these next few turn out to be a "tough dog" like the last 2, I'll smell a rat.
          I.E. some other wanna-be monitor repair guy tried fixing these before giving them to me.
          • lucky13
            • Aug 2007
            • 412
            Aren't we all wanna-be monitor repair guy in the beginning?
              09-07-2024, 05:50 AM
            • howardc64
              Samsung UN55JU650DF network/streaming problem
              by howardc64
              Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
              This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
              07-09-2025, 12:44 PM
            • alro7779
              Samsung UN55MU6103F video problem; has colored stripes on the display
              by alro7779
              Hello, everyone!
              A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
              09-27-2025, 11:29 PM
            • vincentedel
              Samsung SyncMaster 740n Phase Control Issue
              by vincentedel
              I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
              I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
              04-22-2025, 12:33 AM
              09-06-2024, 11:40 PM
