AOC CQ32G2SE no standby, no power on
  • tehmatix
    • Nov 2012
    • 174
    The stand-by LED doesn't turn on. I have checked voltages on the main board 3.3v, 1.2v, 1.8v, 5v. On inverter board, signal for ENABLE is missing.
    Code main board is 715G9500-MOA-B07-0H5K
    I need a dump for eeprom
  • Dani_2024
    by Dani_2024
    10-28-2024, 05:06 PM
  • JDC
    (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
    by JDC
    ONN 100012588
    Issue: No Power, Then Rebooting After Main Board Change
    Short answer: replace main board and power board
    Technical answer: replace main board and Q306 & Q307 on power board.
    Long answer:
    TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
    07-15-2022, 07:39 AM
  • LemoneyF
    Hisense 50r6- no standby, no power, bad main board?
    by LemoneyF
    Hi all
    I have a Hisense 50r6 that quit suddenly, immediately after turning it on. It no longer shows red a standby light and will not turn on. Completely dead.
    I have tested the power supply and found the following:
    363V and 373V across the input caps
    bri- 0V
    ana- 0V
    vamp-17.03V
    vamp-17.03V
    stb- 0V
    12V- 9.3V
    12V- 9.3V
    To the extent of my knowledge (...not far!) these numbers are normal for a Hisense power supply in a standby state, though I would like some confirmation that 9v...
    10-12-2022, 07:44 AM
  • stylishconsultant
    un60j620dafxza - Samsung No Display Problem
    by stylishconsultant
    Hi All,
    Need help.
    I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
    So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
    problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
    might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
    09-04-2024, 03:26 AM
