Re: Daytek F19AH
Could you possibly explain you last post a bit more? Does that mean the secondary of the transformer in not providing the voltage to pin4 of IC101? IC101 being the SMPS controller? Confused here.
Daytek F19AH
Re: Daytek F19AH
It was this exact unit here. Just a cheap direct from Hong Kong thing but it does what its supposed to.
http://cgi.ebay.ca/ws/eBayISAPI.dll?...m=150501632382Leave a comment:
Re: Daytek F19AH
I'm trying to figure out meaningful tests. The problem appears to be that the tertiary winding is not providing run voltage to the SMPS controller.
What brand and model of 0-30V power supply did you get? I'm interested in the specs.
PlainBillLeave a comment:
Re: Daytek F19AH
Alright something I tried today was removing the 10uf cap next to the big filter cap since that is the only one that wasn't replaced brand new and still no go. According to the analog meter when this cap fills up the transformer clicks at the same time it discharges back to 0.
When around the board again and took some voltage readings again after installing the new SG6841.
IC101:
1-2 = 0~1.3v
1-3 = 11~19v
1-4 = .000~.298v
1-5 = 1.1~1.9v
1-6 = .000~.030
1-7 = 10~16v
1-8 = .000~.457v
Filter Capacitor = 158~163v (Usually around 162.5v)
Opto-Isolator pins 1-2 = .812~2.3v
Transformer - 161v in 0v out
Rectifier by filter cap and coil:
Pins 2-3 116vac
Pins 1-4 162vdc
IC1: all readings = .000-.040
IC4:
1-2 = 0v
1-3 = 0v
1-4 = 0v
1-5 = .825v
1-6 = .820v
1-7 = .850 ~ .9v
1-8 = 0v
Also for this monitor I have gotten some new tools.
I have a 0-30v variable power supply in for if I need to "APPLY" voltage somewhere to this board as well a a multi-meter with more options that my current. I included a pic of the multi-meter in case any of the function may be handy for figuring this out.Leave a comment:
Re: Daytek F19AH
Re: Daytek F19AH
Did not workStill no output voltage from the transformer though it remains clicking. IC101 now has it's 15~19v input voltage back and voltage has also returned to pins 1-2 of the opto-isolator but monitor still will not power up.
Re: Daytek F19AH
So my replacement SG6841's finally came in. Just finished installing it. Plainbill, your suspicions about that chip were correct. I know have the clicking back in the transformer. Gonna hook everything up now and see if it works.Leave a comment:
Re: Daytek F19AH
OK so I just ordered a 10 pack of SG6841SZ chips for IC101 and a kickass soldering/rework station for getting the little bugger off the board. This monitor WILL live again.
edit: Pretty bad that I know the numbers "SG6841SZ" off by memory nowLeave a comment:
Re: Daytek F19AH
1) Is the heatsink connected to ground?
**Not sure where to check that. Tried continuity setting from heatsink to the screwholes on each corner of the board and nothing. I put a pic with the 2 heatsink legs in red.
If you look at your photo, you can see that the legs of the heatsink are sharing real estate with other components, like the negative lead of one of the caps you replaced (next to R143)? Yes, it's probably grounded.
2) Is D108 isolated from the heatsink? One probe on the the heatsink and the other probe on the tab of D108 will tell you.
**27.6 ohms
This number could be influenced by other components on the board.
3) Is the middle leg on D108 internally connected to it's backside metal tab? Again, a resistance check will tell you.
**00.3 ohms
Looks to be internally connected.
Since the power supply is not working, a further test would be to isolate D108 by taking off the screw and gently prying it away from the heatsink and placing a thin piece of cardboard between the heatsink and D108 to ensure total isolation. Turn on the power supply.
If you still get nothing, you can try testing D108 off the board again. If you get the same results, then PlainBill's comments about IC101 maybe true.Leave a comment:
Re: Daytek F19AH
Re: Post 97
**27.6 ohms
**00.3 ohms
Re: Heatsink <-> Ground..Leave a comment:
Re: Daytek F19AH
I will verify the last post in the morniong as Ive drank a few wobbly pops tonight lol. WHat I can say though is when I put D108 back in they board and put the screw in **THE RUBBER PAD -WAS- INSERTED BETWEEN THE DIODE AN THE HEAT SINK**.Leave a comment:
Re: Daytek F19AH
Bravo to you for wanting to continue on! I'll put in my two cents worth. Going back to D108, if you look at the third photo on post #51, you notice that the screw holding it to the heatsink is going through a nylon insert and there's a square grey silicon pad (used for heat transfer and insolation) between D108 and the heatsink. It looks like the manufacturer is trying to electrically isolate it from the heatsink. The back of D108 has a metal tab, which some manufacturers internally connect to the middle leg (cathode) of the diodes.
The question is that when you re-inserted D108 did you remember to use the grey pad and nylon insulator? Now, if the heatsink is connected to ground and the metal tab is somehow in contact with it, then the output of D108 could be shorted to ground.
Things to check/verify with power off (you can perform checks in circuit):
3) Is the middle leg on D108 internally connected to it's backside metal tab? Again, a resistance check will tell you.Last edited by jetadm123; 09-02-2010, 08:05 PM.Leave a comment:
Re: Daytek F19AH
Now we'll punch some holes in that scenario. The arc should reduce the output of the inverter transformer. The inverter controller should detect that and shut down; it's a safety feature. As an alternate scenario, the solder joint on one of the drive pins breaks down and an arc forms. Again, the inverter controller should shut down before the transistors fail. Now IF the transistors fail, this would overload the power supply. However, that would have to be be a low resistance - certainly less than 10 ohms, probably less than an ohm. And you have established that isn't the case.
Re: Daytek F19AH
If the inverter transformer did fry out would that just make the light tubes go out or would that give cause for the power LED and everything to go out??Leave a comment:
Re: Daytek F19AH
Refer to the schematic on the datasheet. R5 and R7 (750K ohm each) provide voltage to pin pin 3 of IC101. The voltage at pin 3 will vary depending on the load presented by IC 101, C9 (pdf), and D4 (pdf).
**I'm still having a real difficult time converting that schematic to my board.
Been looking for about 3 days now for a schematic/service guide for this thing an 0 luck.
Hmm, you have a point. Double check the orientation of the diode you circled in orange. If you have it in backwards it will limit the voltage at pin 7.
**Diodes are all in correct ways
One other point which you should take into consideration. I'm used to seeing dark spots on the PC board in the inverter area. These are usually due to heat generated by the transformer drivers. And indeed, I see some darkening between J31 and the two 22 ohm (red, red, black) resistors. However, there is a much darker spot nearer to the transformer. The only component that could be responsible for that is the inverter transformer.
**Would we not have to figure why the transformer stopped clicking before voltage will reach the inverter??
I also went over every solder joint I previously did and still cannot get the transformer to resume that clicking noise like it had before. For some reason I keep thinking I screwed something up by forgetting to solder in D108 before plugging it in.
My other point was that if the darker spot was caused by the inverter transformer we have an explanation of why the monitor smelled burnt.
Re: Daytek F19AH
I also went over every solder joint I previously did and still cannot get the transformer to resume that clicking noise like it had before. For some reason I keep thinking I screwed something up by forgetting to solder in D108 before plugging it in.Leave a comment:
Re: Daytek F19AH
I think is has be something before the IC101 because it had 15~19 volts before coming into it and now it only has 4.27v at pin 3. In order for IC101 to work properly would it not need the proper voltage coming into pin 3? There is something holing back the full 15-19 volts coming into IC101's input.
Re: Daytek F19AH
I think is has be something before the IC101 because it had 15~19 volts before coming into it and now it only has 4.27v at pin 3. In order for IC101 to work properly would it not need the proper voltage coming into pin 3? There is something holing back the full 15-19 volts coming into IC101's input.Leave a comment:
Re: Daytek F19AH
Is there anything to try next? I don't know what to do here.Leave a comment:
Re: Daytek F19AH
This power board is seriously starting to piss me off nowLeave a comment:
by ohrenI hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
The models launched in 2018 and 2019 respectively.... -
Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
I'm new to soldering but the only feasible way to fix this issue is to do something myself.
MY QUESTION:
I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)... -
by YanlebHi all, I just want to share the repair of my 60PK550-UA TV set.
The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
C57: 3.30V
C61:...07-20-2023, 12:38 AM -
by mferna14Hi dear friends., I am working on a Apple MacBook Pro A1708 , Logic Board 820-00840-A that has no backlight. The logic board powers on fine, but no display. After Checking on the backlight driver chip, I found that the EDP_BKL_EN is missing. And this Power Enable comes from the PCH. So does this means this Logic board cannot be repaired & brought back to life again? The resistance from GRD to the test point of EDP_BKL_EN is around is 0.66M ohms. R8442 (0ohms) is ok. Any suggestion/Tip if any would really appreciate.
by mferna14Hi good Friends., today working on a Macbook Pro A2289, Logic board 820-01978-A. The history was liquid spill, Cleaned & replaced all corroded components & now the logic board shows 20v & .01amp on the meter. Not taking in any amps. Upon trouble shooting I get the required stable voltages 5V, PP3V3_G3H 3.3V but no PP3V3_S5. Checked the schematic, assume that this is generated from U7800. Checked all the Input/Output voltages on this chip. All is fine, except PP3V3_S5 is missing. Resistance from GND to PP3V3_S5 is 146 Kohms. First I need to make sure whether PP3V3_S5 is generated from...
- Loading...
