Hyundai B91a (backlight Problem )
  • garrymc123
    • Apr 2010
    • 336
    • United Kingdom
    Hi there all her is a another Little project of mine that i could do woth some professional advice i got this monitor of a friend . here told me that it turns of after half a hour. when i got it home i pluged it my pc and sure enough i turned of but its just the backlight that is turning of. so i opened it up checked the inverter board but no obvious signs so i checked the capacitor with a meter and it was supposed to be ( 25v 470uf ) but it read 510uf so i replaced it thinking that was the problem. so i put it back together and it still done the same thing. so i thought it must be a heat problem. so i pulled out the hair dryer and when i blew it over the board sure enough the back light cut out and i also did this in a dark room because i could here a crackling noise when it was cutting out to see if i could see a spark or something but couldent see anything
    here are some pics
    hope someone can help me resolve this problem ie what components to check
    thank you
    Your never to old to learn
  • NxB
    • Feb 2009
    • 1595
    Re: Hyundai B91a (backlight Problem )
    whats under the green board
    • Krankshaft
      • Jan 2007
      • 2328
      Check for bad solder joints crackling is probably arcing.
      That green board should be removed and checked too I'm betting it contains the PWM for the inverter. No idea why they would mount it like that though.
      • Krankshaft
        • Jan 2007
        • 2328
        Hopefully the IC isn't one of those epoxy blobs and that's why there is a separate board.
        • EGuevarae
          • Nov 2008
          • 1336
          I've seen that in several Samsung Units. It's like a board by it's own.
          • ASUS ROG Maximus IX Code
          • Intel Core i5-7600K 3.8GHz
          • Windows 10 Pro x64
          • GeForce GT1050
          • garrymc123
            • Apr 2010
            • 336
            • United Kingdom
            Thanks guys for the advice i have removed the small green circuit board
            but can,t see anything of the obvious.
            small circuit board pic
            where is the pwm so i can check it or any other connections or components to test.
            thanks
            • mcfischer
              • Dec 2008
              • 12
              I think you should sub the backlights and try the heat test. Your symptoms steer me toward suspecting weak bulbs or bad connections to the bulbs. Reminds me of the Dell 19" model that would work for a long time then shut off the backlights. Cycle power and it works again for a while, sometimes for a shorter time until shut down. All cured by replacing backlights.
              Mike
              • Dobrowol
                Asus GA402RK keyboard and kb backlight problem
                by Dobrowol
                Hi. I have a problem with Asus ROG GA402RK. The keyboard suddenly stopped working along with the kb backlight. I replaced the keyboard and the ITE KBC chip and the problem is still the same. I don't see any passive elements that look damaged. Does anyone have an idea?
                04-28-2025, 04:30 PM
              • ononos
                LG M2362DP Backlight problem
                by ononos
                hello everyone!
                As the title states i am an owner of an LG flatron M2362DP 23 inch monitor Tv. Since i currently use it as a tv i'm posting the problem on the "troubleshooting tvs and video sources" section.
                I'm from Greece so English isn't my native language, so please forgive me for any mistakes i make. I have basic knowledge in electronics, and although i have a degree, many things have changed since i finished a 2 year coarse (over 30 years ago). Occasionally i repair easy stuff, mostly things that break at home like appliances.
                So i decided to try to...
                03-12-2023, 05:05 AM
              • fanaticgames
                Samsung UE32D4010 Backlight problem, led ok
                by fanaticgames
                hello I have a backlight problem on this TV, if I unplug the cn201 cable the backlight works perfectly and the voltages are 13v if I connect the cn201 cable the backlight goes off and the voltage drops to 12v, I assume it's a motherboard problem, the question is has anyone had a similar problem? I want to understand if the motherboard is repairable or it's not worth wasting time...
                02-22-2023, 09:46 AM
              • Honziq
                Backlight problem - Asus M3200WU, board Gapal LA-L291p
                by Honziq
                I have this All-in-one PC, after SSD change there is no picture. I was found out it is a backlight problem, but LEDs are OK. There is 4 led strings each working on 42,4V, but from board is comming only 5V.
                I was repaired many backlights before but this design i will not understand.
                For me it looks like it is waiting for some signal from screen to start up the backlight or something like this. Nothing seems to be damaged or shorted here.
                Can someone explain me please what to do, what to check?
                Thanks....
                11-20-2024, 01:24 PM
              • grbo92
                Backlight problem Acer LA-031P
                by grbo92
                i have one acer Nitro 5 without backlight on my desk.
                Mainboard model: LA-L031P GH53Z REV 1B
                Attached schematics and boardview are REV 1A, slightly different as REV 1B.
                11411_LA-L031P-Acer_Nitro_5_AN515-45_AN517-41-GH53Z_Rev_ (1).zip
                Repair history: customer cleaned dust and changed thermal paste, shortly after that there was no light
                Notebook boots without problem and shows only image without backlight, HDMI output working. Optical inspection done, no burned or broken components. Tested also with a new display module....
                09-09-2024, 03:49 AM
