Viewsonic VX2235WM White Display
  • sghill99
    • Mar 2010
    • 52
    Replaced all Caps, still have a white display. I'm assuming the backlight is working but no signal, therefore white screen. If you need more info, let me know.
    Any suggestions?
    Thanks Much!
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Viewsonic VX2235WM White Display
    All white means the back-light is working but the video chip isn't.
    No signal would not normally give a white screen if the video -chip- is working.
    Default output from the chip [as you would get with no signal in] is a blacked out screen.
    Might also be a connection problem between the video circuit and the LCD.
    Mann-Made Global Warming.
    - Dr Seuss
    • PlainBill
      • Feb 2009
      • 7034
      Any suggestions?
      Thanks Much!
      Two. PCBONEZ is correct with suggesting you check for a connection problem. Within the past week someone had the same problem, they had forgotten to hook up the cable between the panel and the logic card.
      There is usually a fuse on the 'panel circuit board'. This is a pc board that is part of the panel, often under a metal cover. If this fuse is open it will result in a white display.
      PlainBill
      • sghill99
        • Mar 2010
        • 52
        PlainBill, the fuse you speak of, is it one of those surface mount components, the really really little ones? I've checked and double checked all the connections, so I'm sure that's not where the problem lies... also, I've got a copy of the service manual (80 pages), schematics... I'm just starting out and most of it looks Greek to me...
        Thx, in advance...........
        • seanc
          • Nov 2008
          • 1319
          If you're desperate for something to cross reference, I can take mine apart, would have thought the service manual would be of most use though.
          • PlainBill
            • Feb 2009
            • 7034
            Precisely. It's usually about the size of a kernel of unpopped popcorn.
            Is the service manual a hard copy or a PDF?
            PlainBill
            • sghill99
              • Mar 2010
              • 52
              The service manual is PDF... For experienced trouble shooters the service manual probably is all you would need, but as I'm just starting out, reading it isn't real easy at this point, Seanc... As I grow in experience, I'm sure I'll be able to make use of it/them...
              • pecorporation
                • Aug 2010
                Post the service manual please?
