Samsung ls22d300hs
+ More Options
Posts
  • yucel-yucel
    • Dec 2017
    • 142
    • tΓΌrkey
    Samsung ls22d300hs
    The LCD monitor's power light is on, but there is no image. I found and wrote a similar flash dump, but the image comes and goes. I need a fully compatible spi flash file.
    Safe; LS22D300HS
    Processor; SE1279L-MST
    motherboard; BN41-02118D
    LCD; LTM215HT06
    09-07-2024, 05:50 AM
  • shlomim412
    samsung ua55es6800 - no image
    by shlomim412
    hi
    having problem with samsung ua55es6800
    tv had backlight on, sound working - responds to the remote control but no image.
    check tcon board - had 12v in but no other voltages present.
    when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
    when leaving only left side connected - again no voltages and no image.
    put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
    kept trying to block less pins on the left ribbon cable...
    05-15-2024, 05:00 AM
  • Deeloc
    How to flash SSD 1tb WALRAM controller SM2259XT2G flash samsung NAND V6
    by Deeloc
    I have a 1tb WALRAM SSD (Photo)
    Controller SM2259XT2G (photo)
    Samsung memory (photo):
    Part Number K9DVGB8J1B DCK0
    Name V-NAND V6
    Type TLC
    The SSD itself is detected as 1gb, but is not initialized.
    There is a Sata to USB adapter
    A lot of SMI MPTool, did not flash it. compare flash fail (17)
    K9DVGB8J1B is not listed anywhere
    What to flash?​...
    06-05-2024, 08:32 AM
    09-06-2024, 11:40 PM
