Re: WestingHouse L2210NW Will not power.
Now that I see how you numbered the pins (there is no right or wrong way), my number #1 suspicion is that this transformer is bad.
Your measurements on the secondary pins (pin 1, 2, 7, and 8)
black probe on pin 1, red on pin 2 - .872 ohms
black probe on pin 7, red on pin 8 - justs around from 1.121 to 1.580 ohms
If you watch the youtube video link I posted earlier, that transformer was out be a factor of 10x (950 ohm versus 9500 ohms).
Now you can desolder the transformer and retest out of circuit to make sure that no surrounding component are affecting the measurements (just like the video).
If the numbers are still not identical, the next problem is where to find a replacement and are you willing to pay probably $25 for a replacement?
edit: You can email
http://lcdparts.net/T.aspx
to see if they have a replacement that is not listed on their website. If they do have a replacement ask them for specifications specifically what is the resistance between the secondary pins.Last edited by retiredcaps; 08-23-2010, 05:17 PM.--- begin sig file ---
--- end sig file ---
Originally posted by testas86 View Postnow im not getting any reading on the transformer i did get .885 black 1 red 2 and on black 7 and red 8 out of range but now i just did it again to verify and its all saying out of range.
If 7 and 8 consistently show out of range on the 2k ohm scale, you have an open winding on the transformer.--- begin sig file ---
Originally posted by testas86 View Posthmm ok well i guess ill replace the transformer and go from there--- begin sig file ---
Originally posted by retiredcaps View PostBEFORE you order a replacement transformer, let's see if anyone else concurs that the transformer readings are suspicious. PlainBill?
I'm decidedly old school, and find autoranging can lead to confusing readings. I'd set the DMM to the 20K ohm range and check the reading with the probes shorted together. After that, check from pin 1 to 2 and then from 7 to 8.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Originally posted by PlainBill View PostI'm decidedly old school, and find autoranging can lead to confusing readings. I'd set the DMM to the 20K ohm range and check the reading with the probes shorted together. After that, check from pin 1 to 2 and then from 7 to 8.
Both dmms give a reading of 0.7 ohms when probes are shorted together.
It will be interesting to see the 20km test results.--- begin sig file ---
Originally posted by testas86 View Postat 20k with both probes together i get 0.00 ohms
pins 1 and 2 = .88
pins 7 and 8 = .88
My concern is the fact that the readings keep changing. IF this is operator error, that is one thing; eventually your technique will improve. But if it's an intermittent problem with the transformer or other component, it will be difficult to locate the source of the problem.
Originally posted by testas86 View PostAt 2k ohms i got .880 on both
Let's move on. I suggest it is time to take a look at the CCFLs. This picture album shows what a bad CCFL looks like
http://s807.photobucket.com/albums/y...klight%20lamp/
Be very careful taking apart the CCFL assembly.
PS. You haven't answered yet re the flashlight test.--- begin sig file ---
ok so i have reassembled the monitor and turned it on. At first it worked for more then 2 seconds, about 2-3 mins then i turned it off and moved it and tried it again and it started doing the two second off again. i took a flashlight and tried to see if i could see anything on the screen and its completely black no images at all.
Originally posted by testas86 View PostAt first it worked for more then 2 seconds, about 2-3 mins then i turned it off and moved it and tried it again and it started doing the two second off again. i took a flashlight and tried to see if i could see anything on the screen and its completely black no images at all.
It is possible that probing pin 7 and 8 has uncovered a poor solder joint. I suggest removing the old solder from pin 7 and 8 and putting in new fresh solder. A poor solder might explain the erratic readings on the multimeter? It is point #7 of
https://www.badcaps.net/forum/showthread.php?t=10419
That might also explain why it worked for 2 or 3 minutes until you moved it.
Question: Have you ever seen any pink hues in the last month of use? A pink hue is a sign of an aging CCFL drawing more and more power. The extra power draw will cause the inverter IC chip to shutdown the backlights.--- begin sig file ---
There should only be new solder on the joints i used a desoldering iron to remove all solder from the transformer before removing it, and i got this monitor broken it was brought in to my work for recycling so i dont know about the pink hue. i will disassemble the monitor again and re solder all the joints and ill check the ccfl's to see if they are bad.
Originally posted by testas86 View PostThere should only be new solder on the joints i used a desoldering iron to remove all solder from the transformer before removing it,
The only thing that I can think of right now is poor solder joints somewhere on the board or a bad CCFL.--- begin sig file ---
ok so new development i just plugged it in to test it all again with out doing anything to it. i just wanted to make sure everything was not working like it was before. this time i didnt get any power light and i did get a electrical burning smell. i took it apart and it smells like its coming from the other transformer. i did i reading on that one and i got nothing everything was out of range.
Originally posted by testas86 View Postthis time i didnt get any power light and i did get a electrical burning smell. i took it apart and it smells like its coming from the other transformer. i did i reading on that one and i got nothing everything was out of range.--- begin sig file ---
