Velodyne 10 question ?
  • bianchi77
    • Jun 2016
    • 1121
    Dear Members,
    I have Velodyne 10, it's on and responding to low frequency,
    but the speaker is not vibrating properly,
    Is it possible that the speaker is faulty or the amplifier ?
    The speaker resistance is 7.8 Ohm when I put on meter, but I'm not sure it's ok.
    Because it was getting a surge before,
    I've fixed the bridge, switching FET and FET driver before, and also
    the amplifier chip and FET are replaced,
    Is it possible the speaker was burned as well, even it's 8 ohm, it's faulty ?
  • kasfamily
    • Aug 2014
    • 774
    • Russia
    Re: Velodyne 10 question ?
    Maybe there to ask https://www.badcaps.net/forum/forumdisplay.php?f=34
    • waigy
      Nikkai EAPA 450 car amplifier rear speaker output is a low level and distorts easily
      by waigy
      As the title.
      I think these used to be sold in maplins a lot of years ago, it is an antique, but it's just fine for my needs.
      It looks basic enough inside with large components so I could do a full recap pretty easily.
      Any suggestions on what component would cause the symptoms of low volume output on both left and right rear speaker outputs?
      If I turn up the rear gain level in the amp until the speakers start to distort it starts to distort quickly even though the speakers are still pretty quiet.
      I thought I had dodgy speakers as I just fitted new old stock 6x9s in...
      11-08-2024, 03:53 AM
    • Sik_6ty_Sixx
      HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
      by Sik_6ty_Sixx
      So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
      02-18-2025, 05:06 AM
    • silver60618
      Macbook M3 A2991 Speaker Audio Amplifier IC
      by silver60618
      Im working on a 2023 Macbook Pro M3 A2991, that had a liquid spill, has no sound. Corrosion found near Speaker Audio Amp IC. Chip ID SN012776B0,
      I did find a SN012776B0 on A2442 model, but the sub and replaced it, no go. Anyone know if these audio amp IC's are cross compatible between 2021-2023 models?...
      09-26-2025, 12:25 PM
    • Cornboats
      faulty loudspeaker amplifier-no sound output
      by Cornboats
      I've several amplifiers of different sizes which are faulty. I haven't fixed them because I haven't a clue. This is the smallest culprit. 240v in (UK) and 12v dc to the board. Small neon lights when power button is on. Different dc voltages across all of the capacitors. Where do I go from here?
      04-25-2024, 04:43 AM
      HP ProDesk 600 G5 + Bluetooth Speaker 400 ProDesk 600 i7-9700 Specification for Upgrade or Repair
      This specification for the HP ProDesk 600 G5 + Bluetooth Speaker 400 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Bluetooth Speaker 400 boardview and ProDesk 600 G5 + Bluetooth Speaker 400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
      09-12-2024, 02:30 PM
