Dell ST241B Monitor
  • mzb
    • Jan 2021
    • 20
    Dell ST241B Monitor
    Hi folks I am new to this forum, so please bear with me.
    My monitor first became pinkish at the bottom half of the screen and then second day it became blank. If switch on with the same pinkish colour at the bottom left of the screen and the screen goes off exactly after 10 sec. I am enclosing the photos of the power panel with voltage reading and screen shots. These screen shots were taken using CCFL inverter. You will see the left of the screen is illuminated and right sides are dark. The 10sec. switch off to me indicate some caps are gone, but apparently they seems ok as you can see in the photo.
    I just want to be assured that it is the back light and not any other problem. Thanks for your help.
  • HTR-Informatique
    by HTR-Informatique
    02-09-2025, 06:51 AM
  • ChristianBr01
    Dell 34 inch U3419W Monitor with thin stripes on partial screen
    by ChristianBr01
    I have a Dell U3419W Monitor that has some thin stripes on a part of the screen since Tuesday.
    This lines cover about a third of the screen and appear for 2 seconds before disappear for another 2 seconds.
    This repeats the whole time. I have not opened the case yet cause I had no time, but will try to fix it on this weekend. For me, it looks like a problem on the TCon... Am I right?
    Does someone have seen this before?...
    05-23-2025, 06:06 AM
  • Borse2008
    Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
    by Borse2008
    Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
    I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
    • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
    • There’s
    07-15-2025, 04:55 AM
  • Swedishpower
    Dell G3 15 3500 black screen
    by Swedishpower
    Hello
    I have search everywhere for a solution for my problem, but cant find it anywhere.
    When I was away to trow some garbage i always look in the electronic bin.
    and this time i find a laptop.
    Dell G3 15 3500, when I get home i look at the battery, add one harddrive, plug in the powercord.
    the lamp for charmig is white.
    Tryed to start it, the screen blink for a second, the keyboard lightsup, the fans and HD starts.
    but no Dell logo.
    I tryed with a hdmi cable to another screen, still black.
    I started to search solution and tryed...
    07-06-2025, 06:18 AM
  • turmix
    AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
    by turmix
    Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
    The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
    At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
    During another reassembly, I made a mistake, and...
    01-29-2024, 03:48 AM
