Samsung S22F350FH firmware killer
  • eniac22
    • Jun 2012
    • 124
    • Greece
    After firmware update the screen is not working.Where can find older version of the firmware?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8292
    Re: Samsung S22F350FH firmware killer
    I've pulled mine a couple of years ago. It's a slight different model, since my screen size is bigger (LS24F350), but you could try it. As this point you got nothing to loose. I've pulled it with an RT809H ISP mode through the vga port. Good luck!
      09-07-2024, 05:50 AM
    • GeckoGreen
      Samsung service bulletin: need firmware file for PN63C550 TV
      by GeckoGreen
      I'm hoping someone with access to the Samsung GSPN can help me. I need someone with access to download a firmware file for my PN63C550 TV, as it will fix a problem per the Samsung service bulletin.
      You can reference Samsung bulletin #:ASC20130528001 and I need the [2D63]LOGIC.bin file please.
      The full service bulletin is linked here: https://www.avsforum.com/attachments...3-pdf.1080602/
      Will you please help me get the [2D63]LOGIC.bin file for my TV?
      05-17-2025, 02:47 PM
    • Mirenia
      Samsung UEMU6199U - no Standby - bad Firmware?
      by Mirenia
      I've got a Samsung UEMU6199U which has no Standby LED and no reaction if try turning it on.
      Voltages on the power supply board is okay. Backlight test is also okay.
      I read about a corrupt firmware on IC1604 on some models, did a dump of this IC and turns out: First sectors are empty.
      So I think my TV has exactly this issue.
      Can someone please fix the dump?
      And how do you do that?
      As I understand you fill in the empty sectors and leave the rest as it is. But where do you get the "information" of what you...
      05-12-2025, 06:13 AM
      09-06-2024, 11:40 PM
