Keeping back lite on without signal
+ More Options
Posts
  • tubetech
    • Jan 2010
    • 5
    I have a 17" Acer AL1717A LCD screen with a cracked LCD! I have removed the LCD and it makes a terrific Lightbox for viewing slides - however as there is no signal the lights go off after a short time. Can any one help me with a workaround to cheat it into thinking it has a signal.
    Tubetech
  • PlainBill
    • Feb 2009
    • 7034
    Re: Keeping back lite on without signal
    Tubetech
    The cable that connects the power supply / inverter to the logic card contains two lines which control the inverter. These are often labeled BL_ON and BRI or something equivalent. Measure the voltage on these two lines, then rig up voltage dividers to provide those voltages. You can now eliminate the logic card.
    PlainBill
    • tubetech
      • Jan 2010
      • 5
      Thanks for the reply PlainBill
      I have an 8 way cable between "logic board" and PSU/Inv it has 2 Vcc 5volt, gnd, on/off, bright, gnd, volume, mute. so between the on/off and bright perhaps?
      Tubetech
      • PlainBill
        • Feb 2009
        • 7034
        Tubetech
        I'm not sure we are communicating correctly. Let me spell it out in detail:
        Step 1. Measure the voltage from Gnd to the Bright pin while the backlight is on. Note this reading as Vbright.
        Step 2. Measure the voltage from Gnd to the On/Off pin while the backlight is on. Note this reading as Von.
        Step 3. Make up a pair of voltage dividers (two resistors in series). These dividers will be wired between 5V and Gnd. Choose the resistors for one divider so the junction will give Vbright. Choose the resistors for the other so the junction will give Von.
        As an example, if Vbright = 2.9 volts, a 3.0 K in series with a 2.2 K will give about 2.9 volts at the junction (3.0 K to Gnd, 2.2K to 5V).
        Step 4. Remove the logic card, give it to a friend who repairs monitors. Connect the two voltage dividers so Vbright and Von get their appropriate voltages.
        As a matter of fact, if you are clever, you can do it with using only three resistors in series. This is left as an exercise to the student. Also, the Von voltage is not particularly critical. Changing the Vbright voltage will change the brightness.
        PlainBill
        • tubetech
          • Jan 2010
          • 5
          That was a big help.
          did as you suggested, ~ 3volt on the Bright and 5.1 volt on the on/off - arranged that - 1 quick flash then off.
          thought to self, perhaps there should be time delay on the on off, so organised that with 1uf tag tantalum and diode with cap to +5 and diode to gnd on/off to junction, no diff.
          Just tried waiting for count of ten and connecting on/off to +5 with a 100 ohm resister, comes on for count of 5 then off. Reconnected logic board and computer stays on.
          Knew a girl like that once - but only once.....
          thanks for your help
          tubetech
          • PlainBill
            • Feb 2009
            • 7034
            tubetech
            Quick guess - there wasn't enough of a load on the power supply. Try adding a 10 ohm, 5 watt resistor from 5V to Gnd. Or of course you could just leave the logic card hooked up.
            PlainBill
            • tubetech
              • Jan 2010
              • 5
              thanks PlainBill - trier with logic card connected just the on/off cable cut didnt make any difference.
              tubetech
              • tubetech
                • Jan 2010
                • 5
                Mind you I wouldn't mind leaving in the logic board - but without a signal it still goes off after a count of 10.
                makes you wonder....
                Tubetech
                • AstutePauciloquent
                  Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
                  by AstutePauciloquent
                  Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
                  I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
                  11-23-2023, 11:02 PM
                  Samsung ATIV Book 9 Lite Notebook Specification for Upgrade or Repair
                  This specification for the Samsung ATIV Book 9 Lite Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Book 9 Lite boardview and Book 9 Lite schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                  09-06-2024, 05:27 AM
                  Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                  This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                  I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                  I am comparing them to a brand new one that I installed
                  The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                  I going to let it run for several days before I remount back on the wall next to the...
                  09-05-2024, 06:48 PM
                  HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                  This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                  09-12-2024, 02:30 PM
                  HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
