monitor AORUS AD27QD - short circuit and tripped breaker.
  • sew333
    • Apr 2017
    • 81
    • Poland
    Hello. I had a good monitor AORUS AD27QD. Yesterday when i was sleep i left monitor on like always. When i woke in morning there was not power in house. Something tripped breaker/fuse.
    When i turn up breaker and power back in,monitor just refused to turn on. So monitor i guess tripped breaker somehow and make short circuit.
    PC starting normally. Only monitor get damaged.
    During night only pc was running and monitor. Other devices was off.
    Is this possible that monitor can trip breaker?
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: monitor AORUS AD27QD - short circuit and tripped breaker.
    Yes, if the bridge rectifier shorts for example it can take out the branch circuit breaker before the fuse in the power supply burns...
    • sew333
      • Apr 2017
      • 81
      • Poland
      Maybe sell pc if i can experience faults in pc in future?
      Somebody said:"Use a quality surge protector on important things and even though the PC works now it may have suffered as well and in a couple months if you experience faults you know why."
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        ^^Bullshit
        Should you replace everything else in the house as well then?
        • sew333
          • Apr 2017
          • 81
          • Poland
          Ok thanks. Tommorow i will get new monitor .Waiting.
          • sew333
            • Apr 2017
            • 81
            • Poland
            I sended to rma. Here is shop RMA message:
            Shop:"We repaired PSU and sending back good monitor to client"
            Is this possible that psu of monitor can trip breaker then if psu inside monitor, failed?
              master hoarder
              • May 2008
              • 12170
              • Bulgaria
              Yes, the monitor PSU could have tripped your breaker when it failed. Not able to see how the PSU is built (would need pictures for that), we can only assume it was either due to:
              a) design fault (bad caps maybe? or perhaps weak rectifiers or hot-running PSU)
              b) manufacturing fault (marginal component installed from the factory and showing as a latent failure)
              c) power surge on the line, which happened to kill only the monitor PSU.
              From these, A and B are the most likely culprits and C is usually rare.
              • sew333
                • Apr 2017
                • 81
                • Poland
                Somebody said this to me:"As others have stated, the most likely issue is a problem with the electrical wiring in the house and it's frying your electronics."
                So he is right that electrical wiring frying my electronics?!
                1 month after damaged monitor psu , halogen bulb get blown and tripped breaker too.
                So is this possible that electrical wiring frying my electronics or he is not right?
                • sew333
                  • Apr 2017
                  • 81
                  • Poland
                  Somebody said that:" It's FAR FAR FAR FAR more likely that something external caused the PSU to die while simultaneously pushing enough current long enough to trip a breaker.... like a floating neutral or lightning strike." Trust him?
                    master hoarder
                    • May 2008
                    • 12170
                    • Bulgaria
                    Unlikely, but may be worth investigating.
                    Get a multimeter and monitor your line AC voltage. In Poland, this should be 230V +/-6%, (so anywhere in the 216-244V AC range is still in spec.) In particular, take a good (heavy duty) extension cord, then measure voltage with multimeter and note the value. After this, take something that uses a good amount of power (hair driyer, space heater)... but something that won't overload your extension cord, of course... and turn it on while plugged into the same extension cord. Note the voltage reading on the multimeter again. You should noticed a voltage drop, but it shouldn't drop too far - probably no less than 20V than nominal. Anything less, and you may indeed have bad wiring / faulty connection somewhere.
                    Sensitive breakers?
                    Could also be a breaker on its way out.
                    How old is the building you live in? Was it remodeled recently, particularly anything on the electrical system?
                    What about telling us which breaker tripped - living room, kitchen, bedroom, or bathroom? What was going on at the time? (I.e. thunderstorm, nearby construction, etc.) The more information we have, the closer we can get to narrowing down the problem. Going by what people say to you without giving them information will usually not get you to any useful or correct conclusion.
                    It's possible. Just not very likely.
                    If you did have weak wiring, you'd notice it probably everytime you plug in something power-heavy into your outlets, as the bigger load would stress the wiring more and the effects of any weak connection will be more pronounced. Hence why I suggested you do the hair driyer test.
                    I don't know if floating neutral applies to you. In the US, most households (mainly individual houses, and not condo buildings that use 3-phase 208V AC) are wired to a center-tapped 240V secondary on the street traffo, giving 2x 120V phases 180 degrees out of phase (so that larger appliances can use the difference between the two taps for full 240V, whereas individual standard plugs are wired to each phase for 120V.) With a floating neutral - i.e. center tap connection from transformer to house ground/neutral becomes weak/lost. This can cause the house neutral to drift around depending on the loads connected on each phase at any given time, and that can lead to one phase going quite a bit over 120V and the other quite a bit under, to the point where electronics burn out.
                    In Europe, if I understand/remember correctly, most households take in only a single-phase 230V AC (or 3-phase if you have industrial/commercial power available as an option, which some small shops do), so I don't think the floating neutral applies to you.
                    • sew333
                      • Apr 2017
                      • 81
                      • Poland
                      Sensitive breakers?
                      Building from 2005. Wasnt remodeled recently.
                      Each time 2 small breakers tripped. One breaker for wall sockets and second breaker for lights.So all electricity goes down.
                      Also when bulb blowed it was a day. When monitor psu it was night.
                        by momaka
                        03-15-2023, 10:17 PM
                        Gigabyte AORUS AORUS 15-XA Notebook Specification for Upgrade or Repair
                        This specification for the Gigabyte AORUS AORUS 15-XA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the AORUS 15-XA boardview and AORUS 15-XA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                        09-06-2024, 09:00 AM
                        Gigabyte AORUS AORUS 15-WA Notebook Specification for Upgrade or Repair
                        This specification for the Gigabyte AORUS AORUS 15-WA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the AORUS 15-WA boardview and AORUS 15-WA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                        Gigabyte AORUS AORUS 15P XD Notebook Specification for Upgrade or Repair
                        This specification for the Gigabyte AORUS AORUS 15P XD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the AORUS 15P XD boardview and AORUS 15P XD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                        09-07-2024, 05:00 AM
                        Gigabyte AORUS AORUS 17G Notebook Specification for Upgrade or Repair
                        This specification for the Gigabyte AORUS AORUS 17G Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the AORUS 17G boardview and AORUS 17G schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte...
                        09-06-2024, 10:50 PM
