Dell E171FP White screen
  • computerbob
    • Sep 2009
    I have 2 Dell E171FP monitors with white screens. I found that the fuse
    on the panel board is open. Does anyone know the size of it and where
    I can buy one
    Bob
  • hcinne
    Dell G15 ryzen edition black screen 2 amber 1 white
    by hcinne
    I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
    07-23-2024, 07:56 AM
  • tmcw
    Dell P2217 - White screen
    by tmcw
    I picked one of these monitors out of the trash at work, it looked a bit dusty, but newish, and the screen wasn't gouged or cracked as far as I could tell, always a good start.
    Brought it inside and found that the screen was pure white when switched on. Pressing buttons seemed to make the brightness a little dimmer (menu screen popping up?) and pressing other buttons made the backlight go off for a second or two, and then come back on again (input switching?).
    I did a quick google on the model, but no threads or pages with any issues for this model coming up. It's a relatively...
    01-05-2022, 09:38 AM
  • harp
    White screen repairs
    by harp
    To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
    Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
    On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
    05-13-2024, 03:43 AM
  • lerros
    Dell P2417H white screen display
    by lerros
    Hi there,
    I have a Dell monitor model P2417H white screen display. The panel is samsung LTM238HL05. I measure test points and don’t anything like VGH, VGL, … still have 5V. Please suggest me some thing.
    Thank a lot!
    05-21-2024, 09:39 AM
  • angel35
    Dell E6430S No screen help request
    by angel35
    I receive an wrong Dell E6430S, Not start no have screen.
    Spec:
    S mean Slim, not normal "fat" E6430, CPU soldered BGA CPU: i5-3340M SR0XB
    Motherboard: Compal LA-7741P QAL70 r1.0 A00
    Symptom:
    Not start no have screen, no have backlight (full black), but board is working, Status LEDs ok, CPU start to hot and Fan spin up. Northbrigs also hot.
    Main Battery charging, and can run form battery (run means you can turn off, CPU is hot, fan works)
    Looks like everthings ok, but not work
    I changed Memory, plug out SSD,(SSD...
    11-24-2024, 12:12 PM
