Commodore 1084s-p1 fault with video.
  • kadird
    • Feb 2018
    • 17
    • turkey
    Hi all, i have a 1084s and that was working fine until yesterday. But yesterday monitor is suddenly stopped and faulty now.
    I want simply upload a video about problem, which parts and areas should i check, can anyone help?
    Thanks.
    https://youtu.be/qiizl8iJRLM
    • 31094
    Re: Commodore 1084s-p1 fault with video.
    it looks like a philips chassis, so it could be the line output transformer failed.
    • R_J
      • 9561
      I would first check for a shorted horizontal output transistor or maybe a shorted diode in the power supply secondary. Are you getting any secondary voltages? there is a service manual for this monitor
      Being an old monitor I would I would check the small caps in the primary switching circuit and it could also be a bad cap for one if the secodary voltages. This power supply has a triac for over voltage protection and that "might" be the sound you are hearing
      • kadird
        • Feb 2018
        • 17
        • turkey
        Yes, it is Philips one. What's the line output transformer, you mean flyback transformer?
        • kadird
          • Feb 2018
          • 17
          • turkey
          Thanks for advices. I dont measure any voltages yet. Only visually controlled around pcb and dont noticed any bad looking caps or transistors. I have service manual, will check soon. Thanks again.
            • 31094
            yes,
            there is a way to test for this.
            but first:
            remove the flyback transistor and test it.
            while it's out, put a 40w lamp ( a traditional one, not led) across the B+ capacitor
            it should light up.
            • kadird
              • Feb 2018
              • 17
              • turkey
              yes,
              but first:
              it should light up.
              Okay ill try it thanks
              • kadird
                • Feb 2018
                • 17
                • turkey
                @stj, I cant spot these points in the pcb, is there any detailed schematics or guide somewhere?
                  • 31094
                  manuals
                  • kadird
                    • Feb 2018
                    • 17
                    • turkey
                    thx again, can u give me part numbers in schematics? for example, which one is flyback transistor, 7512?
                    https://imgur.com/a/KKkkpEw
                    • R_J
                      • 9561
                      Yes, 7512 is the horizontal output (flyback) transistor
                      • kadird
                        • Feb 2018
                        • 17
                        • turkey
                        okay, which one is B+ cap then?
                          • 31094
                          2520 10uf - you should see 128v across it.
                          • kadird
                            • Feb 2018
                            • 17
                            • turkey
                            Hello again. I replaced EHT transformer with new one, picture partly came back but another issue appeared now. Here is the video about new situation:
                            https://youtu.be/GIYkvtMsf28
                            Where should i check now? Caps maybe or?
                            Thanks.
                            • kadird
                              • Feb 2018
                              • 17
                              • turkey
                              I just configure brightness potentiometer on the EHT and problem solved.
                                • 31094
                                you must adjust focus and brightness on the transformer.
                                brightness is often labeled "screen"
                                you need to do focus first, then brightness, then focus again - because they slightly effect each other.
                                • kadird
                                  • Feb 2018
                                  • 17
                                  • turkey
                                  thanks man, i'll do it again this way.
