Panasonic WV-LW2200/G, need dump file.
  • warsztat
    • Feb 2017
    • 190
    • Polska
    Hi everyone, i need dump file from monitors Panasonic WV-LW2200/G , board TNP4CLM0805 REV:2 22GM05T0038. After plug power LED on but not screen, capacitors on power module seem to by ok, but I replaced it anyway without success.
    Sometimes "no signal" will appear for a while.
    Maybe the file replacement will help.
    Greetings to all.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Panasonic WV-LW2200/G, need dump file.
    I doubt very much what you are asking for will solve your issue. I think you may have a PSU and/or Backlight issue that would need tearing down the Monitor and taking some test voltages for us.
    • warsztat
      • Feb 2017
      • 190
      • Polska
      Thank You for your answer.
      Backlight ok. I will check the power module again tomorrow again.
      Dump file still need, I want to check it too.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        You may have to place your DMM on the pin connector before turn on so that at turn on you can observe the voltages and note the change at shut down. You may have to do this several times for the various pins or perhaps is you post clear pics of the boards and connectors I may be able to help you more.
        • warsztat
          • Feb 2017
          • 190
          • Polska
          When power up, voltage power line 12V up 20-25V , this same moment line 5V down to 4,65V, after moment voltage ok. (sorry my bad english) (Belgium 3 - Japan 2, I ) Sometimes on lcd "no signal".
          I can not find schematics or service manuals this monitor.
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            Let me think about this some more. You may in-fact have a BIOS issue.
            • warsztat
              • Feb 2017
              • 190
              • Polska
              I still need dump U20 (EN25F80) and possible U11 (24lc16). Power module checked, it ok.
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                That's correct.
