Baldwin Piano ccfl display
  • nosaj
    • Dec 2014
    • 53
    I have a baldwin Electric grand piano the display is not working.
    http://www.shema.ru/cd/us/2/data/ps2500.pdf
    The DC/AC convertor board had the fuse, C2 , q1 and q2 were burnt. I replaced them and still no light.
    Would there be an easy way to test the ccfl to see if it is ok?replacements are a $100plus.
    Thanks,
    Jason
  • R_J
    • Jun 2012
    • 9624
    Re: Baldwin Piano ccfl display
    Whats the voltage on CN6, Page 10 of the manual lists +12v but also has +5v on pin 1? Do you have a scope?
    • nosaj
      • Dec 2014
      • 53
      It'll be a few days before I can get back to it. But when i do I want to be able to test the ccfl.
      Here is the datasheet on the screen
      http://www.beyondinfinite.com/lcd/Li...i/SP14Q001.pdf
      I'm thinking I could use a laptop invertor board just to test the CCFL would that be correct?
      Thanks,
      JKason
      • R_J
        • Jun 2012
        • 9624
        That should work just don't leave it connected too long as the laptop ccfl voltage may be a lot higher.
        or use another ccfl and connect it to the supply
        • nosaj
          • Dec 2014
          • 53
          All I need to do is make sure it will light up, if it doesn't then it's bad and needs replacement
          jason
          • R_J
            • Jun 2012
            • 9624
            Looks like a new ccfl is under $10.00 https://www.ebay.com/itm/5-7-LCD-Dis...-/122039418983
            • nosaj
              • Dec 2014
              • 53
              Never tore one apart, guess I will see how hard it is on an old laptop screen when I get the invertor out.
              Thanks for the link,
              Jason
              • nosaj
                • Dec 2014
                • 53
                Laptop LCD invertor can that be used to test a ccfl?
                It is from a Dell Latitude d610.
                Thanks,
                Jason
                • R_J
                  • Jun 2012
                  • 9624
                  It should be able to, post a picture. I have a small LS380 inverter that drives a 5" ccfl and I used it to light a 32" ccfl, It was'nt very bright but it worked.
