Viewsonic VX2370SMH
  • foreman
    • Apr 2014
    • 8
    • Turkey
    Viewsonic VX2370SMH
    Hello, I have this monitor since 2013 ,it had bad panel and changed at 8th month of purchase.
    Now my left side of panel have pink hue and pixelated ,I wonder it is caused by panel itself or Graphic signal board.
    My main problem I installed softmccs and pressed the input select button that was when the hell break loose ,it started giving rgbwb colors which known as burn-in ,my keys arent working so I cant use any combination of key sequence ,it doesnt take any signal from hdmi and dvi only vga works.
    is there anyway to reset this board without keys because ı really couldnt find any spare part or service manual about this monitor ,it is like ghost.
    And I knew viewsonic as good brand, judging by the total trouble it gave me till now prooved opposite ,I bought Dell this time but I want to repair it for second monitor maybe I dont know ,any help from you people apreciated ,thanks.
  • foreman
    • Apr 2014
    • 8
    • Turkey
    Re: Viewsonic VX2370SMH
    No one knows how to reset realtek logic board?
    • rddube
      Aspiring Expert
      • Jun 2013
      • 914
      You could maybe read this thread where I found out how to access the factory menu on a Viewsonic (not same model, but worth a try):
      https://www.badcaps.net/forum/showthread.php?t=66461
      • foreman
        • Apr 2014
        • 8
        • Turkey
        Thanks for your answer but my keys doesnt working not even one ,and they are sensorkeys anyway I guess sensor keys arent working like physical switches at least not in my situation ,
        ,what I am looking for is like jumper or pin to reset this logic board so it can take input from all ports and when not enter sleep mode ,because now when I pull the vga it turns to be a disco ball with rgbwb colors.
        Softmccs wrote some part of eeprom which it shouldn't I guess ,never ever install that program it doesnt even ask you to do it.
        • rddube
          Aspiring Expert
          • Jun 2013
          • 914
          Well if the eeprom was written over you're going to have to rewrite it it you can find the .bin file somewhere.
          In the following thread, I found the flash file for the flash memory on a Benq monitor on a Russian site:
          https://www.badcaps.net/forum/showthread.php?t=67285
          and I reflashed the flash chip. Fairly easy to do, but in my case it didn't solve the problem. I got the monitor working thanks to Will62, but it shorted again on the main board so I'm still trying to figure this one out.
          Hope you make some progress and if you need help with flashing either the flash chip or the eeprom, let me know (you'll have to find the source files first however).
          • foreman
            • Apr 2014
            • 8
            • Turkey
            I share some pictures what logic board looks like ,I got some idea but dont know how to implement,
            if I can send same commands as keys from keypad flex port ,but I dont know which pin to sends what command or combination of pins ,any idea about that ?.
            I read your flashing thread about that benq screen ,but that is risky thing for me to do ,unsoldering that eeprom and that isp flasher which I dont have one, plus I could destroy the monitor at least it is working from vga.
            • foreman
              • Apr 2014
              • 8
              • Turkey
              Look at this sensorkey placement it is whole glued there ,even new firms like AOC doesnt make design like this.
              İf this isnt being amateur what is I wonder ,On that day of purchasing this monitor I was certainly one of those days like you feel dumb and numb ,viewsamsonic is history for me after this model.
              • foreman
                • Apr 2014
                • 8
                • Turkey
                Finally I found a solution for normal state operate of monitor
                I used https://www.nicomsoft.com/products/i2c/download/
                this software is the only software really doesnt mess with eeprom parts it shouldnt be
                For the people who are stuck at BURN-İN at viewsonic vx2370 smh is to install this program connect it from VGA port run program and select restore all factory settings wait for it to settle and then click standbye mode it ,monitor goes to standbye wait for 5 sec and voila it opens back with viewsonic logo which indicates everything in order ,especailly for people who are like buttons arent working ,Thanks for helping.
                  by momaka
                  03-15-2023, 10:17 PM
                • wattage
                  AOC AG493UCX 49-inch monitor - Firmware request
                  by wattage
                  Hello Badcaps Community,
                  The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                  07-13-2025, 04:41 PM
                • ant3202
                  HP 27es - LED monitor - Monitor Flashing On - Off
                  by ant3202
                  Hi Everyone
                  Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                  https://www.badcaps.net/forum/troubl...lashing-on-off
                  The monitor is HP 27es LED Monitor
                  https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                  The monitor will randomly blackout and display no signal and will recover again.
                  Sometimes need to power and off again to restore the display but...
                  03-20-2025, 07:30 PM
                • Rick_1234
                  LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                  by Rick_1234
                  Good evening, gentlemen.
                  I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                  To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                  https://drive.google.com/file/d/1L6S...ew?usp=sharing
                  Things I tried
                  - Bought a new AC adapter thinking that was the problem but the problem...
                  06-22-2024, 04:44 PM
                  Wise Wing F199 19'' LCD monitor - recapped
                  by momaka
                  Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                  I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                  When I saw the Craigslist post, I wasn't...
                  08-24-2020, 10:58 AM
