Asus VE247H problem
+ More Options
Posts
  • FrankMtl
    • Sep 2015
    • 36
    Asus VE247H problem
    Hi, I found this broken monitor.
    It`s starts up and turn off about 5 seconds after.
    There is also a small red vertical lines.
    All the caps and soldering look good.
    Should I change the caps anyway?
    Here is the caps list
    On the main PS 330uf 35v x2,680uf 16v x2,22uf 50v
    On the driver 22uf 100v x2,220uf 25v x 2
    On the video board 220uf 16v x2, 22uf 25v x3,10uf 25v
    Thanks.
    Frank.
    • 30977
    Re: Asus VE247H problem
    check the diodes in 2 pairs with the empty space next to each pair.
    putting diodes in parallel is a stupid trick that often fails - just search this forum for "vestel" to see lots of examples.
    • FrankMtl
      • Sep 2015
      • 36
      Thanks, I guess I have to desolder the diodes to test them right?
      I tried to test them on the board and I get an voltage from both ends.
        • 30977
        test them on the board for resistance - if they arent short-circuit then they are o.k.
        • FrankMtl
          • Sep 2015
          • 36
          Hi, can you help with this procedure?
          I have a cheap multimeter that is not autoranging.
          What values should I get ?
          Thanks.
          Frank.
          • FrankMtl
            • Sep 2015
            • 36
            I think I figure it out. I use the 200 setting on my multimeter
            and got 1 fro mon side and voltage on the other on all diodes.
            What`s next to check?
            Frank.
              • 30977
              voltage?
              your supposed to test the diodes with the power off!!!!!!
              • FrankMtl
                • Sep 2015
                • 36
                Yes lol sorry, wrong term.
                Power was off.
                Francois.
                • FrankMtl
                  • Sep 2015
                  • 36
                  Hi, I check all resistors diodes and caps, they test all good.
                  I also check and clean the ribbon cable.
                  I have this vertical red line.
                  Video Board issue?
                  Thanks.
                  Frank.
                    • 30977
                    red line???
                    i see a white "cloud" only
                    • FrankMtl
                      • Sep 2015
                      • 36
                      Here is a better picture.
                      Frank.
                        • 30977
                        if it's always in the same place, it could be the panel.
                        • FrankMtl
                          • Sep 2015
                          • 36
                          Yes always at the same place.
                          • AtelierRepa
                            ASUS X712JA problem
                            by AtelierRepa
                            I have a problem with the bios, let me explain.
                            With BIOS 1, the pc takes +- 30 seconds to display the ASUS logo (black screen) and to boot.
                            I did a clear ME, my black screen problem for 30 seconds at boot is solved, it gives me directly the display and boots quickly.
                            My problem is that now, once the charger is plugged in and I put a slight load on the processor, it bogs down to 0.39GHz...
                            The only solution is to unplug the charger to get the cpu back up to speed. But as soon as I plug in the charger, it goes straight back down....
                            06-15-2024, 04:33 AM
                          • Dobrowol
                            Asus GA402RK keyboard and kb backlight problem
                            by Dobrowol
                            Hi. I have a problem with Asus ROG GA402RK. The keyboard suddenly stopped working along with the kb backlight. I replaced the keyboard and the ITE KBC chip and the problem is still the same. I don't see any passive elements that look damaged. Does anyone have an idea?
                            04-28-2025, 04:30 PM
                            ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook Specification for Upgrade or Repair
                            This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                            09-07-2024, 02:50 AM
                            ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook 15 Specification for Upgrade or Repair
                            This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                            ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook CX1 Specification for Upgrade or Repair
                            This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
