Samsung T220 - Possible Scaler Issue?
  • microbyte
    • Mar 2015
    • Portugal
    Hey all,
    I've been scratching my head around a Samsung T220 which first had a "stuck" button behavior, kept cycling through all the "MagicBright" modes at the maximum speed it could. I was able to "fix" it by adding an extra pull-up resistor to the 1.8V on the KEY2 line. No more OSD popping up all the time.
    Now, when I solved this problem, another one appeared. Now I'm having a strange slight blur on the image (looks like horizontal misalignment), which can only be seen on the image coming from the computer. Maybe 1 pixel only... It's not that it's slow, it is behaving fast, but the image is all blur.
    I've tried both DVI and VGA, the problem persists.
    Also tried with another computer, and the problem is there...
    I replaced all the capacitors on the main board (scaler board), didn't solve.
    The strange part for me is that all the OSD layer can be read perfectly and shows no problem whatsoever.
    Can you help me sorting out this problem?
    I have a scope available which I can use to test something at your will.
    Thanks!!
  • microbyte
    • Mar 2015
    • Portugal
    Re: Samsung T220 - Possible Scaler Issue?
    Hey all,
    Just to finish the thread, I'd like to say that there is nothing wrong with the board nor the display. Actually, it is pretty embarrassing: for some reason, the "sharpness" settings on the monitor has been reset to 0 and thus my image was blurry (and the OSD was fine)
    So, thanks anyway for anyone that read this.
    I hope this last post helps others having the same "issue".
    Best regards!
    • Kjell
      Samsung Series 9 - BIOS issue
      by Kjell
      After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
      Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
      08-01-2025, 09:15 AM
      09-07-2024, 05:50 AM
    • Nairolf
      Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
      by Nairolf
      I have a Samsung DM32D display.
      When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
      Here’s what I have tried so far:
      1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
      2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
      3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
      From these tests, I suspect the problem might be on the mainboard. Could anyone...
      08-24-2025, 03:47 AM
    • vincentedel
      Samsung SyncMaster 740n Phase Control Issue
      by vincentedel
      I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
      I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
      04-22-2025, 12:33 AM
    • Manucsl
      QE65Q800TATXXC Samsung TV Issue
      by Manucsl
      Hello.
      My TV is a QE65Q800TATXXC Samsung TV.
      Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
      Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
      Any ideas to check would be very appreciated 😊
      After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
      02-19-2025, 07:47 AM
