Acer 7257c startup issues....
  • stevo1210
    • Oct 2006
    • 4156
    I received a bunch of free monitors (LCD & CRT) from a family friend yesterday and the majority of them work fine.
    But there's one monitor which has some weird issue with starting up. It's an Acer 7257c 15" CRT monitor.
    It takes 5-10 minutes for the monitor to start brightening up, colours are shown at the same time, and the colours all look OK at 1024x768 32bit.
    Only problem is that it doesn't get bright enough like other monitors. It's a bit dim when it's "fully bright" and that it takes too long to start up.
    When I received it, the monitor looked like it had been in a very nasty environment.
    There were drip marks of some liquid like oil, the stains were in the rear section on the top of the monitor. There were small amounts of this oil where the vents were, but I opened the monitor up to check it yesterday, the PCB deirectly underneath the section where the vents and oil marks were had no stain marks.... nothing apart from dust.
    I did however take the shell of the monitor out and gave it a good cleaning with cleaning agents + water, because of the dust etc. sticking to the shell. The shell is very clean now. And yes, I did dry the whole shell yesterday + the small piece of foam at the back.... So I can rule out water damage.
    The CRT tube of the monitor is made by Toshiba and the GUI interface of the OSD looks exactly like my Diamaond View/ Mitsubishi one. I found no bad caps on the PCB so I think the caps are still OK.
    But it's very strange because if I turn off the PC and leave the monitor in standby, next time I start it up, it will start instantly, same goes if I turn off the monitor with the power button, but leave it plugged in.
    If I unplug it from the powerpoint for a few hours, it will have issues turning on. If I remember correctly, If I was to unplug it for a minute or two, it will still startup instantly.
    Thanks.
  • stevo1210
    • Oct 2006
    • 4156
    Re: Acer 7257c startup issues....
    I solved that now, I just got to wait for 15 minutes or so for it to get "fully bright" like other CRTs.
    But when it's "fully bright", the brightness isn't stable, I can see it dimming and brightening very slightly, not a lot, but I can definitely see it and it does get annoying....
    Is the CRT tube starting to die out or is it something else?? The text and images on this CRT look wonderful at 1024x768 24bit colour, 60Hz, but it's a shame that it takes sooooo long to start up and also the dimming and brightening......
    • Rainbow
      • Aug 2005
      • 1375
      Check the tube heater voltage. It should be 6,3V usually. Bet your is too low. Trace it to a voltage regulator somewhere on the PCB and check nearby caps. I had similar problem with my Iiyama 17" CRT - there was a cap (100uF IIRC) with high ESR near the regulator's heatsink. It was just bad, no bulging. Replaced it with 330uF and it works fine. Also check for bad solder joints.
      • estabilito
        Acer Nitro AN515-55 weird behaviour on startup
        by estabilito
        Hi, I've just repaired acer nitro an515-55 with specs:
        i7-10750h, rtx2060.
        Laptop had damaged cpu and after replacement came back to life but i have weird problem with this machine.
        After night or 2-3hours on first startup laptop shows acer logo, windows circle for second and then screen goes blank - machin stays on but i need to turn it off by holding power, on next startup laptop working just fine.
        i've tried different bios, different vbios and same behaviour - clean windows install too.
        Do you have any idea?
        08-13-2025, 02:52 PM
      • maralexbar
        How to force Acer Aspire Series to bootup BIOS/UEFI on external Monitor?
        by maralexbar
        I ask this question in general as there are many Acer Aspire models with UEFI Insyde BIOS that do not boot to the BIOS on an external monitor (VGA, HDMI, etc) showing only the Internal LCD (LVDS, eDP etc).
        It's a pain to work on Acer notebooks with a broken screen and not being able to access the BIOS using an external monitor.
        If anyone knows how to force the external monitor as primary for Notebooks of those models
        11-02-2024, 09:18 AM
        09-06-2024, 05:27 AM
        Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
        This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
        09-07-2024, 05:00 AM
        Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
        This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
