PL2010M flickers once when turned on, then black
  • primuspaul
    • Dec 2020
    • 56
    Any way to fix? Anything else to check? I saw no obvious bad caps.
  • primuspaul
    • Dec 2020
    • 56
    Note this unit has an external psu.
    • primuspaul
      • Dec 2020
      • 56
      Tried a different compatible 12v5a psu and same result.
      • CapLeaker
        Leaking Member
        • 8135
        I see some bad caps on the main board like C505. Also take out and reseat that square IC.
        Probably your back light disappears, because of the inverter board or the lamps. Measure the resistance of the high voltage secondaries of the 6 transformers. If they are not within 2%, the inverter board won't work. Also check those blue high voltage caps and the connectors for bad solder joints. Generally look at anything that has weight and or high heat for cold solder joints.
        • primuspaul
          • Dec 2020
          • 56
          How can I tell C505 is bad? I don't see the usual signs like swollen top or leaking.
          • primuspaul
            • Dec 2020
            • 56
            Is there some way for me to test the capacitors without desoldering each one? The only equipment I have is CL800 clamp meter and a Fluke 115.
            • primuspaul
              • Dec 2020
              • 56
              I found some brown residue on C61. Gonna try to replace that and see if it works.
              • CapLeaker
                Leaking Member
                • 8135
                That c505 got hot as the sleeve shrunk. Worth checking it out. I’ve seen caps they look brand new, yet have no capacity. So you can’t go by looking at capacitors alone. The reason you backlights fail is because a very high chance of one or two transformers being bad.
                • primuspaul
                  • Dec 2020
                  • 56
                  OK. I'll see if I have a compatible cap and replace c505 and c61.
                  • primuspaul
                    • Dec 2020
                    • 56
                    Replaced both. Same symptoms
                    • CapLeaker
                      Leaking Member
                      • 8135
                      Check the resistance of the 6 transformers and write it down.
                      • primuspaul
                        • Dec 2020
                        • 56
                        Which items are the transformers and how do I test them? Do I need to desolder them to do this?
                        • Sam Scarbo
                          • Oct 2023
                          • 38
                          This chip looks bad. Is it burnt?
                          • CapLeaker
                            Leaking Member
                            • 8135
                            Hard to tell. Sometimes a picture does 100% showing a hole or a chip missing. But under a microscope it looks different and nothing wrong. Happened to me just a couple of days ago to one of my threads. Clean the chip up and look again, I that chip would be dead, your monitor wouldn”t be doing what it is doing now. Again, check the resistance of these transformers,
                            • CapLeaker
                              Leaking Member
                              • 8135
                              On the board with the backlights (second pic, in your first post) measure the resistance of these 6 red looking transformers on the secondary high voltage side and note it down. Then compare them to each other. No you don’t have to take these transformers out.
                              • primuspaul
                                • Dec 2020
                                • 56
                                Is that better?
                                • primuspaul
                                  • Dec 2020
                                  • 56
                                  Not sure I measured the right pins. https://app.cimediacloud.com/r/XYrWmscRCtQC
                                  • CapLeaker
                                    Leaking Member
                                    • 8135
                                    The measuring points are correct, you just had your meter set to capacitance, not the Ohm setting (resistance). So you have to measure again and write the results down.
                                    • CapLeaker
                                      Leaking Member
                                      • 8135
                                      Is that better?
                                      could be some other residue on the chip. That what it looks to me.
                                      • lotas
                                        • Jan 2016
                                        • 4576
                                        • Russia
                                        U601 - TPA6030A4
                                          HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                                          This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                                          09-12-2024, 02:00 PM
                                          MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black N4000 Specification for Upgrade or Repair
                                          This specification for the MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Cubi N 8GL-063DE/N4000/4GB/W10P/Black boardview and Cubi N 8GL-063DE/N4000/4GB/W10P/Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-12-2024, 01:58 PM
                                          Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-07-2024, 05:00 AM
                                          Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 04:10 AM
                                          LG Gram LG gram 16Z90P-K.AA85A1 16GB_512GB - Black Notebook Specification for Upgrade or Repair
                                          This specification for the LG Gram LG gram 16Z90P-K.AA85A1 16GB_512GB - Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the LG gram 16Z90P-K.AA85A1 16GB_512GB - Black boardview and LG gram 16Z90P-K.AA85A1 16GB_512GB - Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
                                          09-07-2024, 03:40 AM
