Re: ASUS VH222 has no image
OK I think I fixed the problem using your solution. The monitor appears to be stable after many hours of normal usage. I placed rubber pads on top of the tabs and they're now stablized. Thank you all!!!!
Not easy, I never bother fixing bad tab bonding on monitor. I use thermal transfer pad, you can use rubber pad to press down on the tab. The bad part is that you have to take the panel apart again and just do not cause more or new damage.
https://www.badcaps.net/forum/showthread.php?t=25371
I think the top tabs are loose. The other night I was able to let it run without problem for an hour, because I remember repositioning the TCON board (which is connected to the taps). Do you see anything unusual? The third picture shows some glue on the side tap.Leave a comment:
https://www.badcaps.net/forum/showthread.php?t=25371Leave a comment:
"When I was disassembling the monitor previously, at one point I opened the screen assembly. So maybe I ripped some cables there?" OK, that is one important info, it sound like the bonding between the LCD glass panel and the long PCB has loose tab bonding. The connections can expand from the heat of the lamps, they do get pretty hot.Leave a comment:
Primary negative and secondary ground can have a different voltage, so that potential could have damaged the mainboard or also the tcon bd but you will never get on top of this i think, it is much probably damaged one of the bigger chips, from the few i know... you can if you want try to find a new main bd or leave it so if it don't hurt too much..Leave a comment:
When I was disassembling the monitor previously, at one point I opened the screen assembly. So maybe I ripped some cables there?Leave a comment:
I would try cooling the logic board first, then the T-CON board, if the problem is on the T-CON, then that will be real difficult to repair.Leave a comment:
You said to find the bad component. Is there any standard procedure I can follow to test? I can't even find the fuse on the PSU. Sorry I'm such a noob.
And lastly, if I don't fix this problem, will it hurt the monitor? I mean it's not very noticeable at all.Last edited by ucdzombie; 12-26-2013, 10:45 PM.Leave a comment:
OK will do. If this is the problem, will there be a long term fix solution? Like installing a heat sink??Leave a comment:
You can't see the burn mark in the picture because it's taken before I assembled it.Leave a comment:
You may try cooling the board with canned air using it upside down for cooling to see if the problem will disappear since the problem seems to happen after warm up.Leave a comment:
If you look at my first post with the picture, it's the big metal bar on the right. What happened was that I accidentally placed some wires (wrapped) between the metal bar and the protective metal shell. When I plugged it in, it made a spark right there because I saw some burn mark on the wire wrapping and the metal bar, as well as the metal shell. So maybe the wire wrapping conducted electricity and it shorted something? But the monitor worked fine afterward for 15 minutes.Leave a comment:
Do you think the spark I made yesterday from the accident could have burned something? How comes it's so random?Leave a comment:
have you seen if each cable is isolated well now? try to locate where the spark gone from.. i think now your monitor is more of there that of here..Leave a comment:
Logic to T-CON. Also make sure all the board mounting screws are tight since it uses the chassis as the ground.Leave a comment:
OK will try this tomorrow. But I think it's pretty tight already. Are you talking about the one that goes from the PSU to the logicboard? Or the the one from the logicboard to the TCON?
Also, this symptoms goes away if I unplug the monitor for more than 15 minutes.
One last thing, when I was installing it today, there was an accident. The cable from the switch panel was placed between one of the heatsinks (I don't know what's it's called. But it's the big metal bar) and the metal shell. When I plugged in the monitor for the first time, it made a spark. I thought screwed up the monitor. Later I fixed the cable, and it turned on fine. And then this symptom appears after 15 minutes or so.Leave a comment:
Did you already try re-seating the LVDS cable?Leave a comment:
by DynaxSCHi,
Usually on ASUS boards it worked...-
This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...09-07-2024, 02:50 AM
This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...09-07-2024, 02:50 AM
This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...09-07-2024, 02:50 AM
This specification for the ASUS ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year boardview and ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...09-07-2024, 01:30 AM
- Loading...
