Ok to replace 25v 470uf with 25v 1000uf?
+ More Options
Posts
  • JoeyJoe
    • Sep 2012
    • 76
    I replaced 6 bulging caps on a power board, but still nothing happens on the screen.
    Could possibly be another cap that was inline, but I'm wondering if the caps I replaced them with are too high rated.
    This is on a Samsung 2032BW.
    Re: Ok to replace 25v 470uf with 25v 1000uf?
    Yes, that can cause problems, especially if you use crap caps like Maplins and some eBay sellers distribute.
    • JoeyJoe
      • Sep 2012
      • 76
      ... some generic ones from ebay. Have worked wonders on other monitors. I have some new better low ESR ones coming... maybe I should wait for them.
        Not just enough to be "low ESR"... also have to be high quality e.g. Panasonic, Rubycon, United Chemicon/Nippon Chemicon, Nichicon, Sanyo...
        • JoeyJoe
          • Sep 2012
          • 76
          I fixed a monitor I am using with some eBay caps, and it has been fine. Today I turned it on and it was quite dark. I turned it off and on, and it was back to normal brightness.
          Is this to do with the caps?
          Also I did buy some other caps, the brand is "Suntan", are these shite?
          • Heihachi_73
            • Jun 2012
            • 713
            Suntan are cheapo caps we get over here (Australia) at Jaycar Electronics along with "S.I.", but even those are good enough to at least fix a TV or set top box.
            By the sounds of it, there might be more bad caps. Make sure the bad caps didn't pass on the bad cap "virus" to the main board (my LCD had a cap killed on the main board due to 3 bad Samxon caps in the PSU passing on excess ripple).
            • JoeyJoe
              • Sep 2012
              • 76
              Ok, just bought 20 Panasonic caps to make up for it.
              I will open it up again and check the other caps. Only replaced the blown ones.
              • ssl6
                MSI K7T266 Pro (Ver. 1.0)
                by ssl6
                Hey Everyone,
                Long time lurker, but I think this is my first time posting.
                Just looking for some assistance on identifying some suitable replacement capacitors for an MSI K7T266 Pro (Ver. 1.0). I just got my hands on two of them actually, both working but one has some visibly bulging capacitors and the other has a few that I can't tell for sure if they're bulging because it's faint at best if they are.
                I'll be honest I don't fully understand much on capacitor spec sheets beyond voltage and capacitance but I can solder like nobodies business so I've...
                11-09-2023, 01:00 PM
              • Kingpin!
                3COM OfficeConnect Gigabit Switch 16
                by Kingpin!
                3COM OfficeConnect Gigabit Switch 16 (3C1671600)
                The switch has served me for 10+ years (was new when I bought it). It's a nice switch with connections on the back which makes for quite a clean desk. Reason for taking it apart was that the cooling fan was noisy so I expected it to be dirty/dusty inside and the need to order a new fan. What I found was that it was very dirty/dusty and some electrolytic capacitors which needs attention. There are 3 capacitors which needs to be replaced but the ESR on some of the other ones might be bad as well so I think I'll replace them all. Original...
                09-17-2023, 04:58 AM
              • mrdevil
                Crest Smart Home Single Power Adaptor SHSPM1 (rebadged Tuya device) - bad cap causing failure, how to repair
                by mrdevil
                Wanted to share this as I couldn't find anything on the internet about this problem, so pulled one apart and found the problem myself. Years ago I bought approx 20 or so Crest Smart Home Single Power Adapter smart switches - small 240v Tuya-compatible (rebranded) smart switch devices with power monitoring, which Big W had on sale for half price. Paid $7.50 each for these, and they've been incredibly useful for turning things on and off remotely... and monitoring how much power each device uses.
                However, after about 12 months, I had a number of these stop working...
                01-08-2025, 03:19 AM
              • P4C800
                ASUS P5A and P2B-S recapping. Searching old datasheets.
                by P4C800
                I'd like to recap some of my old mainboards (they are from 1998) before switching them on again for the first time after many years in storage. All caps still look good from the outside.
                There are three mainboards:
                - ASUS P5A rev 1.04
                - ASUS P2B-S rev 1.03 "Rubycon"
                - ASUS P2B-S rev 1.03 "Chemi-Con"
                If you are interested in their specs, The Retro Web has pages for the P5A and the P2B-S.
                They all have many 1000uF 6.3V 105°C capacitors. But there are some differences I cannot figure out.
                P5A
                10-09-2023, 05:55 AM
              • jasenpeters
                EMPREX - LM-2601 - Sw26B - ILPI-082
                by jasenpeters
                Emprex - 26" LCD Monitor - Mfr. Date: May 2008
                History:
                - Recently purchased from a thrift shop, and went dark after about 2 weeks.
                Symptoms:
                - Blank black screen, smell of burned component, computers still detect monitor (as Sw26B).
                Inspection:
                - Took the monitor apart to find a control board and a power board.
                - The power board (ILPI-082), near a pair of output leads to the monitor screen, had a visibly burned and ruptured ceramic capacitor, with the following markings:
                12J
                3KV
                JNC
                12-25-2021, 02:02 AM
