Viewsonic VG700b odd caps
  • Hemingray
    KABOOM!
    • Jul 2010
    • 143
    Have this from my dentist's office, exhibits the 2sec to black symptom. Inverter board has two "N?Con" caps. What's odd here is these caps are 56uF/25v (one is bulged). What can I get to replace these? (there's two of them)
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Viewsonic VG700b odd caps
    Use a 68µf or 100µf 25v capacitor.
    Pictures? Sounds like it could be in a ventless can, just because of the voltage and capacitance.
    Muh-soggy-knee
    • mockingbird
      • Dec 2008
      • 5484
      Are they green and they say "EVL" on them?
      Here you go:
      http://www.digikey.ca/product-detail...1818-ND/589559
      Make sure the diameter matches (These are 5mmx15mm)
      • Hemingray
        KABOOM!
        • Jul 2010
        • 143
        Yeah. Exactly that. I had two 47uF Nichis handy, so I tried those, and surprisingly, it works! Also replaced a bloated 330uF/16V Teapo near the BL connector on the main logic board. Think it'd be ok to leave the 47s in there?
        • mockingbird
          • Dec 2008
          • 5484
          Sure. Remember they're 47uF +/- 5%.
          • Hemingray
            KABOOM!
            • Jul 2010
            • 143
            Out of boredom, I drug the three bad caps across my tester. The bloated 330uF teapo actually tested better than the two "NKCON" 56uF caps. Neither of the NKCONs even managed to reach 1uF on the meter (and one of them wasn't even bloated!). The teapo managed about 92uF.
            • mockingbird
              • Dec 2008
              • 5484
              It's not just about the capacitance... If the caps internal resistance gets too high, the cap overheats. Chuck them in the trash.
              • Hemingray
                KABOOM!
                • Jul 2010
                • 143
                I will. After I drag em across my massive 24V transformer for a little fun
                  by momaka
                  03-12-2025, 03:42 PM
                • eryjus
                  by eryjus
                  05-10-2023, 11:21 AM
                • Paxman_Swede
                  by Paxman_Swede
                  Hello!
                  01-14-2025, 09:51 AM
                • captain150
                  by captain150
                  03-16-2025, 07:34 PM
                • Foetuss
                  Gigabyte GA-6OXT :: caps question
                  by Foetuss
                  Good evening
                  I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                  Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                  But I was also suprised about the bigger boys, which are 330µF 25V.
                  Could it be they used 25V caps because they were cheaper / available at that time?...
                  02-11-2025, 12:22 PM
