ViewSonic VX2835WM
    ViewSonic VX2835WM
    Is it possible to get a high quality snap shot of the power board of this monitor? Most images are taken from the side where all the capacitors are attached. I need a high quality image of the other side. I need this to verify a tracer connection between a diode and resistor. I've seen the image that is currently available on this power board, but it is a bit blurry, and I can barely make out the tracer. I probably have it right, and can proceed with capacitor replacement, but I thought I would double check with a less out of focus image.
    Thanks!
    Tim
    Re: ViewSonic VX2835WM
    hi - You need to do is to your original post from "Intro" -no one will reply to it on there
    I did ask mods to move it but no joy.
    Also post pictures of your boards and close ups of the problem area.
    Welcome to the forum-
    We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back (in the same orientation) and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
    Examples of what is needed
    https://www.badcaps.net/forum/attach...7&d=1280167246
    https://www.badcaps.net/forum/attach...6&d=1280167246
    https://www.badcaps.net/forum/attach...4&d=1280167246
    It will be useful if you can say what the supposed fault was and a bit about yourself - skills tools etc.
