samsung syncmaster 510n not optimum mode
  • alihomee
    • Dec 2012
    • 1596
    • malaysia
    i have problem with samsung syncmaster 510n. its power is ok but when i connect it to pc it shows (not optimum mode recommended mode 1024*768).what is ment by this .i have been change resolution to 124*768 but found no display on monitor .it only shows the message mentioned above.so i want to know where is the fault
  • Lastpatriot
    • Jul 2012
    • Turkey
    Re: samsung syncmaster 510n not optimum mode
    Hi. There can be many reasons.It seems like ''VGA Cable''. Try with another vga cable first.If not, then check resolution frequency, must be 60 hertz.
    • UniT3d
      • May 2011
      • 43
      Hmmm .....
      Does your 510n uses the novatek NT68F63 IC ? If yes then try the (47 or 50 Ohm) resistor hack at pin 5-6.
        09-07-2024, 05:50 AM
      • fulepost@outlook.com
        Samsung "QE" series QE55Q70RATXXC Intermittant restart in "home mode".
        by fulepost@outlook.com
        Dear all.
        I'm a less knowledgable member who would appreciate some guidence.
        I have a Samsung QE55Q70RATXXC that works perfectly in "shop mode" but in home mode it restarts, Intermittantly.
        With intermittant I mean the TV can work perfectly for a week and suddenly start to restart. Before the restart it may reach different stages. Sometimes it restarts when the "QLED" start screen shows up and some thimes it restarts after hours, and everything in between.
        When the restart occurs, the screen blacks out leaving a light area alomng the edges fading...
        11-09-2025, 07:10 AM
      • soopacrucial
        Samsung Syncmaster 740BF repair
        by soopacrucial
        Hi folks,
        I'm new here and was wondering whether you might be kind enough to give me some advice on troubleshooting the following problem:
        Quite a few years ago now, a couple of years from new, my Samsung Syncmaster 740BF LCD monitor starting playing up by making a buzzing noise and then the display would go blank. I seem to remember the blue power led would also go off when this happened but that I'm not 100% sure of. By pressing the power button I do remember I could at first get it working again but eventually the problem would come back. At the time I had read about...
        10-29-2024, 02:40 PM
        09-06-2024, 11:40 PM
