ask for my samsung 743nx lcd monitor
  • ariefkoes
    • Dec 2012
    • indonesia
    I am having problems as above (function PCB Samsung 910), but this is for samsung lcd monitor 743nx type. the original is a touch button.
    This is a sequence of buttons samsung 743nx : power, auto adjust, enter, move up, move down, menu.
    I intend to replace the touch button to switch button for touch button can no longer be used because of a fluid leak lcd (now my lcd panel is replaced with a new one)
    there are 4 pins that go into the old touch button: 3.3 v, key 1, key 2, led, gnd.
    please help if you have a schematic diagram for my guide makes use swich button Function Panel
    while I am trying to create a function panel following the schematic diagram for the type 910mp as above.
    This link for samsung 743nx images from his official web, is using the touch button,
    I want to replace it with a switch button.
    http://www.samsung.com/my/consumer/p.../LS17MYAKF/XME
    09-07-2024, 05:50 AM
    by momaka
    03-15-2023, 10:17 PM
  • glutton4punishment
    Samsung monitor Installed 1 cap wrong, now menu button dead, "no signal detected" msg
    by glutton4punishment
    Samsung synchmaster 226BW.
    Before I replaced 5 caps, the screen was dim.
    Sometimes it wouldn't turn on.
    I opened it up, and found 4 bad caps in the pwr supply section.
    I unfortunately installee one backwards, i.e. wrong polarity.
    When I turned it on, I head a loud pop, and I quickly shut it off.
    The replaced caps are 3 860uF 25V's, and 1 330u 35V.
    One of the 860uF blew.
    I didn't have another 860uF at home, so I tried it with a 1000uF 35V cap (I remember the reading of the 1k uF cap was close...
    03-18-2023, 12:49 PM
    09-06-2024, 11:40 PM
