Hello all
Has anyone experienced an arching between power supply and lcd panel ?
I bought 3 Non working viewsonic 28” monitors VX2835 wm with a no start no power problem , tested all caps and replaced the bad ones. Put it back together worked great for after about 4 hours I heard a pop like a fire cracker. Opened it up checked for popped caps, I get no power but I did find a burned mark on the back of the lcd panel. Power supply has burned marks near some resistors and Mosfet solder looks bad.
I can only think that heat expanded monitor or power supply to touch the back of the LCD panel.
Would I be able to put a non conductive material behind on power supply as a shield With out over heating power supply?
I repaired another monitor same model as above and place masking tape on
the back of lcd panel just under power supply hope that works.
