Samsung 943N
    Samsung 943N
    can someone help me with the inverter transformer for this model? I can't find it to buy, or equivalent to TM-1017.
    Thanks.
    Re: Samsung 943N
    Hi - is this a sole transformer or dual transformer set.
    If dual you need to measure the primary and secondary winding resistances
    in order to look for an alternative.
    If a single type is one of the secondary windings ok - if so you need to measure that.
    It would also be useful if you were to post at least your country and mains voltage.
    You could also post in the wanted classified forum.
      Re: Samsung 943N
      have a look in these photos.
      https://www.badcaps.net/forum/showth...t=Samsung+943N
        Re: Samsung 943N
        I'm from Romania, voltage 230. On S1 = 932ohm, S2 -> 1Mohm. I can't tell if both S are down, but i think there are, because the spec says that S1/2 = 983ohm.
          Re: Samsung 943N
          Unless you made a mistake in measuring or typing, S2 is bad because it is 1,000,000 ohm (1M). If you meant 1K or 1,000 ohms, then one of the transformers is bad because both are outside 3% of each other.
          Replacements are available on ebay like this one
          http://www.ebay.com/itm/160784404587
          --- begin sig file ---
          --- end sig file ---
