Hanns.G HG281D Monitor - Cycles on and off randomly
  • mooses
    • Dec 2011
    • 11
    This monitor is 3 years old now and the problem I have with it is when it goes to sleep (computer off no video signal) it will sometimes turn itself on (LED Blue) and then go into standby (LED Orange) and then switch off (No LED light).
    It'll just cycle through that while it's plugged in and left on.
    However when I want to use it, if the LED isn't blue at the time it can take up to 20-30 minutes for it to turn on by itself.
    Once the monitor is on it works fine and there are no problems until I turn off the PC or the monitor goes to sleep.
    Any idea what the problem could be? I'm going to open it up soon to take some pictures but I just need to get me a temporary monitor to use before I do.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Hanns.G HG281D Monitor - Cycles on and off randomly
    Likely dried up caps with high ESR. As the lcd warms up, the cap's ESR drops allowing the circuit to work. See
    https://www.badcaps.net/forum/showthread.php?t=11329
    --- begin sig file ---
    --- end sig file ---
      by momaka
      03-15-2023, 10:17 PM
    • Ifixstuff9
      Dell SE2416h monitor power cycles - very weird behavior
      by Ifixstuff9
      Hello all,
      I have a dell SE2416h monitor that power cycles at somewhat random intervals. When the monitor is first powered on after being off for a few hours, it lasts 15-30 mins before the first power cycle. After that, the cycles progressively get more frequent until the monitor cycles every few seconds.
      I'm not sure what is causing this, but maybe something is overheating, causing the monitor to shut off? That would explain why it gets worse with time.
      Now here is where things get weird (at least to me, this might be some some common symptom I've...
      04-20-2019, 07:03 PM
    • wattage
      by wattage
      Hello Badcaps Community,
      07-13-2025, 04:41 PM
      Wise Wing F199 19'' LCD monitor - recapped
      by momaka
      Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
      I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
      When I saw the Craigslist post, I wasn't...
      08-24-2020, 10:58 AM
    • sew333
      Pc shutdown, monitor flickered with no signal after 10 seconds
      by sew333
      My pc:
      10850K stock 4800mhz stock Kraken X73 good temps
      2x16 GB DDR4 GSKILL 3000mhz XMP
      Seasonic Tx-850 Ultra Titanium
      Gigabyte Rtx 3090 Gaming OC
      Aorus Z490 Pro Gaming
      1 TB SSD
      4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
      Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
      Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
      Power...
      02-22-2022, 10:27 AM
