I am trying to save an acer that someone gave me. When I first got it, it was staying on for 10-30 secs then the backlight would die. I got it running by turning the brightness down (default is 100) to about ten. it stayed on for an hour so I thought I was good and started incrementally increasing the brightness to around 25 without issues. I then placed it in its final home and of course it then decided to crap out on me. now it it doing 2 secs to black. the video shows up fine with a flashlight and I cranked the brightness all the way down again. I notice that the brightness starts at the level where the settings say it should be then within half a second seems to max out then die. also there is a faint whining that is on the upper range of my hearing coming from the board but i can't pin point whether is is one of the inverters (this board has two) or one of the caps (cheap Su'scon caps) near the inverters. I just would like to get a more experienced opinion than mine to see if these symptoms are a perfect match to some particular component before I fire up the soldering iron and go hunting for compatible components. the board and solder joints look pristine (one small surface burn on one of the inverter contacts but it goes across the silicon not along the contact so I am assuming its from manufacture not a symptom). Thank you
acer al1916w was funtioning now ccfls dead
Re: acer al1916w was funtioning now ccfls dead
I have a Benq 17 inch monitor that behaves in the same way. Luckily I had 2 identical monitors and through the process of swapping out boards and components, I narrowed the problem down to the ccfls and/or its wiring as the culprit.
I haven't taken it apart yet (and this is over 1 year) to actually look at the ccfls because it is time consuming and delicate work.
As the ccfls age, they draw more power.
Basically you are looking for what is described here
https://www.badcaps.net/forum/showthread.php?t=10419
in posts #19 and #20. Start with section 5) Bad CCFL/wiring. Other possibilities might be bad inverter transformer, bad caps, and others.Last edited by retiredcaps; 02-17-2012, 04:23 AM.--- begin sig file ---
--- end sig file ---
by bripollHello, I have an Acer veriton n4670GT that, due to a fall to the ground, only started if I did a BIOS reset.
The power button ar ok, and when power off windows, then if press power button, this power on, but goes to boot loop, like press power button forever
It crossed my mind to try a BIOS update and when I finished it turned off and no longer starts in any way.
I have a flash programmer, but the file you download from the Acer website has a .CAP extension, it is not a .BIN
I have programmed it, but it still won't start, it is dead
Before programming...-
11-23-2023, 02:56 PM -
This specification for the Acer Aspire Aspire 9920 G-933G64HN can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Aspire 9920 G-933G64HN boardview and Aspire 9920 G-933G64HN schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 05:27 AM
This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...09-07-2024, 05:00 AM
This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...09-07-2024, 05:00 AM
This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-07-2024, 04:10 AM
- Loading...
