Samsung SyncMaster Model 731N Distorted Display
+ More Options
Posts
  • jayoung
    • May 2011
    • 172
    I received a Samsung SyncMaster 731N today from the local computer store. Monitor functions as expected, but the image is distorted horizontally (see images). I took apart the monitor, and swapped out the lcd panel and the ribbon cable to the lcd panel with no change. Multiple computer inputs and cables have been utilized. As you can see in the image, the OSD appears normal.
    Nine capacitors on the power / inverter board are all Su'scon. On the video board, four capacitors are Su'scon and six capacitors are TEAPO.
    There are several threads on badcaps.net for this monitor, but they are for no display.
    Anybody have any ideas what could be causing this? Thanks in advance.
    I can get and attach pictures of the power / inverter board and / or the video board if needed.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Samsung SyncMaster Model 731N Distorted Display
    I would suspect a problem on the signal (video) board, probably in the video input circuitry.
    PlainBill
    • jayoung
      • May 2011
      • 172
      PlainBill
      Anything in particular to check?
      • PlainBill
        • Feb 2009
        • 7034
        I'd check voltages on U101 and U102 - the LDO regulators. I'm going on the belief that there is noise on the analog input signal, so the caps are also suspect.
        PlainBill
        • jayoung
          • May 2011
          • 172
          U101:
          A1
          AS117L-33
          BO637 26
          Pin 1 - 0.00 VDC
          Pin 2 - 3.30 VDC
          Pin 3 - 5.16 VDC
          Pin 4 - 3.30 VDC
          U102:
          A1
          AS117L-18
          BO552
          Pin 1 - 0.00 VDC
          Pin 2 - 1.39 VDC
          Pin 3 - 5.15 VDC
          Pin 4 - 1.39 VDC
          I had to order some parts from digikey.com for another job, so I ordered replacements for the 10 capacitors on the signal board at the same time. I was also thinking that there may be noise from 1 or more of the capacitors causing the issue. I see that the voltage on U102 is low also (1.39 VDC vs. 1.80 VDC). Not sure if that is from a defective regulator or not?
          • retiredcaps
            • Apr 2010
            • 9271
            AS117L-18
            Definitely defective. A voltage regulator should be within 1% of its specs. In this case,
            1.8 x 0.99 = 1.782
            1.8 x 1.01 = 1.818
            --- begin sig file ---
            --- end sig file ---
            • jayoung
              • May 2011
              • 172
              I've tried finding a replacement for this part, but have not not been able to find an exact match to the part number. I have found AMS1117-18, LD1117-18, LM1117-18, L1117-18, etc., but no AS117L-18.
              I think this is the datasheet for the original regulator:
              http://www.alldatasheet.com/datashee...A/AS1117.html?
              Would this part be a possible replacement? I may be able to call digikey.com tomorrow morning and get this added to my order.
              http://search.digikey.com/us/en/prod...9-5-ND/2472287
              Thanks in advance!
              • retiredcaps
                • Apr 2010
                • 9271
                Any of those will work. Just make sure the size/package is correct. They are "jellybean" parts and made by a lot of different manufacturers.
                • PlainBill
                  • Feb 2009
                  • 7034
                  I'm going to throw a warning out here. At this point the best option is to replace the regulator. However, there is a significant chance the regulator is fine, something is loading down the output.
                  PlainBill
                  • jayoung
                    • May 2011
                    • 172
                    The ten capacitors and the replacement regulator are on order with digikey.com and should arrive in a day or two. Is is worth replacing the regulator and checking the outcome or should I go ahead and replace the capacitors along with the regulator?
                    • PlainBill
                      • Feb 2009
                      • 7034
                      Regulator first. I don't think a bad cap (or caps) would explain that unusual voltage.
                      PlainBill
                      • sabre504
                        • May 2010
                        • 449
                        • United Kingdom
                        Did you check the input voltage to the regulator ?
                        Scratch that i see you were getting 5+ volts on input was it steady ?
                        • jayoung
                          • May 2011
                          • 172
                          Yes, the input voltage on both regulators was steady.
                          • jayoung
                            • May 2011
                            • 172
                            Success!
                            Ordered arrived from digikey.com today and I replaced the 1.8V regulator. Plugged everything in and the voltage was steady at 1.80VDC and the picture is crystal clear with no distortion. Thanks everyone.
                            • trains58554
                              • Apr 2012
                              • 55
                              Hi All,
                              I have the exact same problem. I was wondering if I could use an ez1117 as the replacement for the as1117-18
                              • jetadm123
                                • 2169
                                Originally posted by trains58554
                                Hi All,
                                For the as1117-18, the "-18" indicates a fixed output of 1.8 volts. Since there is nothing after the ez1117, then I'm assuming the output voltage has to be set using external resistors.
                                • trains58554
                                  • Apr 2012
                                  • 55
                                  Hi jetadm123,
                                  Thanks for your reply there where no other numbers at the end and I did a little more reading and I think you are right about it needing external resistors.
                                  • trains58554
                                    • Apr 2012
                                    • 55
                                    Does anyone by any chance know of any devices that have this chip in them?
                                    Is the 1117m3 compatible?
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      Why not just use the part number provided in post #7 at digikey?
                                      • trains58554
                                        • Apr 2012
                                        • 55
                                        I will probably just end up ordering it from digikey but I figured that it does not hurt to look at the parts I have laying around.
                                          09-07-2024, 05:50 AM
                                        • soopacrucial
                                          by soopacrucial
                                          Hi folks,
                                          10-29-2024, 02:40 PM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
