Samsung Syncmaster 245BW
  • kmoonen
    • Dec 2011
    • 61
    Re: Samsung Syncmaster 245BW
    Ok I will replace that part and then go from there .. Thank you for all the help ..
    • kmoonen
      • Dec 2011
      • 61
      Originally posted by Toasty
      More questions, still no answers...?
      Sorry , Missed those questions
      Model#HUB24-P
      Caps were replaced with Luxon G series.
      • Toasty
        • Jul 2007
        • 4171
        Luxon G is not a series. It's the maker's name, G-Luxon. The series is a 2 letter code on the caps sleeve.
        HUB24-P is the BN44-00173A power supply.
        veritas odium parit
        • kmoonen
          • Dec 2011
          • 61
          ok unless i did something wrong measuring the voltage i got no voltage at all at the f9222l
          also i can hear the transform er making a hissing noise then no noise then hissing like it is trying to start
          • jetadm123
            • 2169
            Suggest you remeasure the voltages. If you read no voltages, then you would not be seeing the 8.6V at the 24V output. Try measuring for the high voltage at pin 23 of the F9222L. Measure the voltage on the side of CM802 that's connected to pin 23, since it will probably easier to get to.
            • kmoonen
              • Dec 2011
              • 61
              #26
              volts dc for all?
              • PlainBill
                • Feb 2009
                • 7034
                volts dc for all?
                Yes.
                PlainBill
                • kmoonen
                  • Dec 2011
                  • 61
                  #28
                  Yes.
                  PlainBill
                  what do i ground to?
                  • PlainBill
                    • Feb 2009
                    • 7034
                    You would use the negative side of the large capacitor. Note that this is a 'hot ground' - dangerous voltages are present. They probably aren't high enough to be lethal, but care is indicated.
                    PlainBill
                    • cooldrifter08
                      • Aug 2013
                      • usa
                      #30
                      where can i buy a TM801s
                        09-07-2024, 05:50 AM
                      • soopacrucial
                        by soopacrucial
                        Hi folks,
                        10-29-2024, 02:40 PM
                        09-06-2024, 11:40 PM
                        09-06-2024, 08:40 PM
