Samsung 2032bw, wrong display, very slow
    Hello
    I have a 2032BW Samsung monitor model. who has a problem.
    The monitor turns on but the display is very very slow, the contrast too saturated.
    When a new image appears, the old image is still a little displayed,
    Reading the text is almost impossible.
    thank you for any ideas
    Re: Samsung 2032bw, wrong display, very slow
    I would take it apart and look for obvious signs of bloated capacitors.
    Also clean and reseat all your connections between cards.
    If that fails, I would suspect the logic/main board. See if this monitor has a factory default setting.
    --- begin sig file ---
    --- end sig file ---
      I have already looked at the capacitors, I saw nothing unusual.
      It's true that a component may be defective but not be.
      For the 2493HM I found the fault immediately, it was easy.
      I think making a video that shows the default screen.
      In France it is said that "good design is better than a thousand words"
      thank you
