Viewsonic VX2235wm fixed
  • Rogerwilco
    • Dec 2011
    • 3
    This monitor was given to me and had no picture whatsoever, but the blue LED on the front panel would come on as normal and change to orange after a few seconds.
    On opening the monitor and checking the PSU/Inverter board I found the expected bloated capacitors, but what I didn't expect was that the main 120uF 400v capacitor was also bulging. This is the first time I've seen that and quite unusual from all accounts.
    What I didn't immediately notice was one leg on the main cap had been arcing at some stage and eventually must have disintegrated as most of that leg was missing amoungst the burnt remnants.
    Anyway, I replaced the caps with suitable replacements and the monitor is now working again. After seeing the main cap was effectively not in circuit I was surprised there was no other Subsequent damage to other components.
    I've included a couple of pictures. The red circles show which were the bloated caps. All faulty caps were CapXon except the main cap which was a TAICON. You can see the scorching on the heatsink from the arcing main cap.
  • cheeky2
    by cheeky2
    05-25-2024, 03:27 AM
  • Dani_2024
    by Dani_2024
    10-28-2024, 05:06 PM
  • ygorsan
    by ygorsan
    🧩 Problem Summary:
    • I
    07-28-2025, 08:34 AM
  • Asraf Atb
    by Asraf Atb
    01-27-2025, 05:02 PM
  • JSin21
    Compatibility of main boards between different variations of samsung MU6100
    by JSin21
    Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
    I have Samsung Smart TV UA65MU6100WXXY version DA01
    Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
    11-27-2023, 04:54 AM
